# lxc config show --expanded ud
boot.autostart: "true"
boot.autostart.delay: "60"
image.architecture: amd64
image.description: Debian jessie amd64 (20200504_05:24)
image.os: debian
image.release: jessie
raw.lxc: |-
lxc.net.0.ipv4.address = 10.0.100.37/20
lxc.net.0.ipv4.gateway = 10.0.100.3
volatile.base_image: 3cac6eacbbc5824812fc576fcf09b7f7bad95ed1f1109a41c5c7575274958bd3
volatile.br0.host_name: vethe3546e06
volatile.br0.hwaddr: 00:16:3e:07:59:28
volatile.br0.name: eth1
volatile.idmap.base: "0"
br0:
nictype: bridged
parent: br0
pool: default
There being mounts under rootfs/ is very unusual and the sign of an issue…
You may want to do nsenter --mount=/run/snapd/ns/lxd.mnt then run cat /proc/self/mountinfo, locate any of those mounts where you have things mounted below rootfs and unmount those. That should clear the issue, though it doesn’t really explain where those came from in the first place…
