I had to do a snap restart lxd
a couple of times to get things back to what looked like a sane state. The first restart took a very long time (4-5 mins) and came back with lxdbr0
not having a inet6 fd42:c8f3:56ae:8db::1/64 scope global
assignment at all. OddâŚ
After the second snap restart:
anderson@anderson-ryzen9:~$ ip addr show lxdbr0
30: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:dc:42:47 brd ff:ff:ff:ff:ff:ff
inet 10.11.12.1/24 scope global lxdbr0
inet6 fe80::216:3eff:fedc:4247/64 scope link
Looks ok, and then after the first RA was sent:
inet6 fd42:c8f3:56ae:8db:216:3eff:fedc:4247/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 3389sec preferred_lft 3389sec
Back to having a dynamic assignment on lxdbr0
The container did refresh its IPv6 address back to 3600sec on the first RA, but it did not on subsequent ones.
After the second RA didnât do anything I reapplied:
lxc network set lxdbr0 raw.dnsmasq="ra-param=lxdbr0,10"
And everything fixed itself with all lifetimes on host and container immediately starting at 3600sec and being refreshed often.
Then I stopped build-armbian
which was the only container running and lxdbr0
lost both the IPv4 and IPv6 addresses:
30: lxdbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
If I start build-armbian
again I see the following on the host and container:
inet 10.11.12.1/24 brd 10.11.12.255 scope global lxdbr0
anderson@build-armbian:~$ ip addr show eth0
37: eth0@if38: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:fa:f9:5e brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.11.12.199/24 brd 10.11.12.255 scope global dynamic eth0
valid_lft 3560sec preferred_lft 3560sec
inet6 fd42:c8f3:56ae:8db:216:3eff:fefa:f95e/64 scope global deprecated dynamic mngtmpaddr noprefixroute
valid_lft 3189sec preferred_lft 0sec
inet6 fe80::216:3eff:fefa:f95e/64 scope link
Multiple start/stop cycles on build-armbian
doesnât fix it once the interfaces get in the preferred_lft 0sec
/ deprecated
state, but they do continue to work due to, I presume, the valid_lft
being non-zero:
anderson@anderson-ryzen9:~$ ping6 fd42:c8f3:56ae:8db:216:3eff:fefa:f95e
PING fd42:c8f3:56ae:8db:216:3eff:fefa:f95e(fd42:c8f3:56ae:8db:216:3eff:fefa:f95e) 56 data bytes
64 bytes from fd42:c8f3:56ae:8db:216:3eff:fefa:f95e: icmp_seq=1 ttl=64 time=0.096 ms
64 bytes from fd42:c8f3:56ae:8db:216:3eff:fefa:f95e: icmp_seq=2 ttl=64 time=0.077 ms
So, another sudo snap restart lxd
to try to get things back to sane:
anderson@anderson-ryzen9:~$ lxc stop build-armbian
anderson@anderson-ryzen9:~$ sudo snap restart lxd
Restarted.
41: lxdbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
anderson@anderson-ryzen9:~$ pgrep -fa dnsmasq
4277 dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=lxdbr0 --dhcp-rapid-commit --listen-address=10.11.12.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts --dhcp-option-force=119,lxd,corp.terasci.com --dhcp-range 10.11.12.2,10.11.12.254,1h --listen-address=fd42:c8f3:56ae:8db::1 --enable-ra --dhcp-range ::,constructor:lxdbr0,ra-stateless,ra-names -s lxd --interface-name _gateway.lxd,lxdbr0 -S /lxd/ --conf-file=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw -u lxd -g lxd
anderson@anderson-ryzen9:~$ cat /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw
ra-param=lxdbr0,60
anderson@anderson-ryzen9:~$ lxc start build-armbian
And back to not refreshing again:
42: eth0@if43: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
valid_lft 3153sec preferred_lft 3153sec
inet6 fd42:c8f3:56ae:8db:216:3eff:fefa:f95e/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 3156sec preferred_lft 3156sec
Applying a different raw.dnsmasq
value fixes it , but only for a single RA:
anderson@anderson-ryzen9:~$ lxc network set lxdbr0 raw.dnsmasq="ra-param=lxdbr0,30"
ra-param=lxdbr0,30
valid_lft 3082sec preferred_lft 3082sec
valid_lft 3587sec preferred_lft 3587sec
// wait a while...
valid_lft 2482sec preferred_lft 2482sec
valid_lft 2987sec preferred_lft 2987sec
So, still trying to figure out what action in particular gets it to refresh correctly and consistently.
