As soon as I manage to import 2 containers, such partition will no longer be mounted, and the disk, formated.
Ok, then you don’t actually want to import them as that would require the drive always be present.
Instead you can do:
- lxc storage create default dir
- rsync -aHASX --devices --numeric-ids /mnt/@/var/lib/lxd/storage-pools/default/ /var/snap/lxd/common/lxd/storage-pools/default/
Which will create an empty storage pool using the dir backend and then move all data from your old drive over.
Once that’s done, you should be able to run lxd recover and have it just scan that default pool, it should then detect the old instances.
I created the storage, and ran rsync (it took almost 8 hours). Then I tried lxd recover with this:
fmello@server2:~$ lxd recover
This LXD server currently has the following storage pools:
Would you like to recover another storage pool? (yes/no) [default=no]:
The recovery process will be scanning the following storage pools:
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]:
Scanning for unknown volumes…
No unknown volumes found. Nothing to do.
Then I tried the alternative setting /var/snap/lxd/common/lxd/storage-pools/default/ as btrfs:
Would you like to recover another storage pool? (yes/no) [default=no]: yes
Name of the storage pool: default
Name of the storage backend (btrfs, cephfs, dir, lvm, zfs, ceph): btrfs
Source of the storage pool (block device, volume group, dataset, path, … as applicable): /var/snap/lxd/common/lxd/storage-pools/default/
Additional storage pool configuration property (KEY=VALUE, empty when done):
- NEW: “default” (backend=“btrfs”, source=“/var/snap/lxd/common/lxd/storage-pools/default/”)
Error: Failed validation request: Failed mounting pool “default”: Source path “/var/snap/lxd/common/lxd/storage-pools/default/” isn’t btrfs
It claims that there is no btrfs, so I tried zfs:
Name of the storage backend (btrfs, cephfs, dir, lvm, zfs, ceph): zfs
Would you like to recover another storage pool? (yes/no) [default=no]: no
- NEW: “default” (backend=“zfs”, source=“/var/snap/lxd/common/lxd/storage-pools/default/”)
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]: yes
Error: Failed validation request: Failed mounting pool “default”: Cannot mount pool as “zfs.pool_name” is not specified
I don’t think rsync has worked. Although rsync created folders from the source path …
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default$ ls
containers custom images snapshots
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default$ cd containers/
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default/containers$ ls
ai2AIDevel ai2AIProd ai2Base ai2CA ai2GitLab ai2Web2 boomerang julia raves s3msPub s3msPub2
… they are empty
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default$ sudo ls ./containers/julia/
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default$ sudo ls ./containers/ai2GitLab/
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default$ sudo ls ./snapshots/
fmello@server2:/var/snap/lxd/common/lxd/storage-pools/default$ sudo ls ./images/
If it took 8 hours then there must be a lot of files in there.
Can you show output of du -h /var/snap/lxd/common/lxd/storage-pools/default?
Yes, there are many files there, although I think it took too long. These are the sizes of the containers:
838M ai2AIDevel
806M ai2AIProd
1,1G ai2Base
746M ai2CA
48G ai2GitLab
16G ai2Web2
3,5G boomerang
14G julia
977M mobileapp
2,3G raves
159G s3msPub
44G s3msPub2
And this is the result of du -h /var/snap/lxd/common/lxd/storage-pools/default
fmello@server2:~$ sudo du -h /var/snap/lxd/common/lxd/storage-pools/default
[sudo] password for fmello:
4.0K /var/snap/lxd/common/lxd/storage-pools/default/snapshots
4.0K /var/snap/lxd/common/lxd/storage-pools/default/custom
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIProd
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2CA
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/julia
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/s3msPub2
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/boomerang
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/templates
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/media
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/sbin
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/dev/shm
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/dev/pts
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/dev
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/sys
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/run
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/sbin
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/include
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/games
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/local
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/bin
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/src
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/dbus-1.0
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/sysctl.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/environment.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/valgrind
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/kernel/install.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/kernel
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python2.7/dist-packages
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python2.7
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/x86_64-linux-gnu
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/gcc/x86_64-linux-gnu/8
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/gcc/x86_64-linux-gnu
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/gcc
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/tc
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/dpkg/methods/apt
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/dpkg/methods
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/dpkg
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/openssh
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/locale/C.UTF-8/LC_MESSAGES
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/locale/C.UTF-8
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/locale
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/multiprocessing
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/http
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/pydoc_data
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/importlib
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/collections
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/distutils
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/sqlite3
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/unittest
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/asyncio
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/curses
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/ctypes
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/test
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/xmlrpc
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/json
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/dbm
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/encodings
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/wsgiref
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/email
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/html
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/lib-dynload
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/concurrent
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/venv
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/pycache
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/logging
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6/urllib
112K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/python3.6
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/klibc/bin
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/klibc
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/sysusers.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/file
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/apt/methods
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/apt/solvers
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/apt/planners
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/apt
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/sudo
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/mime/packages
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/mime
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/eject
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/tar
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/tmpfiles.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/initramfs-tools/bin
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/initramfs-tools/etc/dhcp/dhclient-enter-hooks.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/initramfs-tools/etc/dhcp
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/initramfs-tools/etc
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/initramfs-tools
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/networkd-dispatcher/off.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/networkd-dispatcher/dormant.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/networkd-dispatcher/routable.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/networkd-dispatcher/no-carrier.d
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/networkd-dispatcher
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/binfmt.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/systemd
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/ssl
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/rsyslog
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib/modules-load.d
316K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/lib
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr/share
348K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/usr
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/root
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/opt
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/proc
7.8M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/bin
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/alternatives
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/selinux
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ufw/applications.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ufw
40K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/sysctl.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ca-certificates/update.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ca-certificates
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/cron.hourly
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/cron.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/kernel/install.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/kernel/postrm.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/kernel/postinst.d
28K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/kernel
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rsyslog.d
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/logrotate.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc5.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/gss/mech.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/gss
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/logcheck/ignore.d.server
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/logcheck
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/cron.monthly
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/X11/xkb
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/X11
28K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/update-motd.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/network/if-up.d
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/network
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/iproute2/rt_protos.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/iproute2/rt_tables.d
56K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/iproute2
84K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/pam.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ld.so.conf.d
584K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ssh
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dpkg/dpkg.cfg.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dpkg/origins
24K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dpkg
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/opt
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/netplan
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor/init/network-interface-security
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor/init
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/profile.d
48K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/init.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc1.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/python3.6
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/depmod.d
28K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/cron.daily
28K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/modprobe.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor.d/local
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor.d/disable
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor.d/force-complain
24K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apparmor.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rcS.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/terminfo
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc6.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/vim
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc3.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apt/sources.list.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apt/auth.conf.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apt/preferences.d
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apt/trusted.gpg.d
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apt/apt.conf.d
56K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/apt
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/skel
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/security/limits.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/security/namespace.d
52K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/security
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc4.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/newt
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/xdg/autostart
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/xdg/systemd
24K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/xdg
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dbus-1/system.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dbus-1/session.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dbus-1
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dhcp/dhclient-enter-hooks.d
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dhcp/dhclient-exit-hooks.d
32K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/dhcp
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/tmpfiles.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/init-premount
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/nfs-top
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/local-premount
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/init-top
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/nfs-bottom
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/local-bottom
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/local-top
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/init-bottom
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/panic
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts/nfs-premount
44K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/scripts
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/hooks
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools/conf.d
68K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/initramfs-tools
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/networkd-dispatcher/off.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/networkd-dispatcher/dormant.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/networkd-dispatcher/routable.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/networkd-dispatcher/no-carrier.d
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/networkd-dispatcher
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/binfmt.d
168K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/console-setup
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc0.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/user
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/network
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system/timers.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system/multi-user.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system/network-online.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system/getty.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system/sysinit.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system/sockets.target.wants
28K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd/system
64K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/systemd
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ssl/private
624K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ssl/certs
644K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/ssl
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/cron.weekly
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/rc2.d
48K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/default
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/udev/rules.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/udev/hwdb.d
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/udev
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/modules-load.d
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc/sudoers.d
2.8M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/etc
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/boot
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/x86_64-linux-gnu/security
8.7M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/x86_64-linux-gnu
96K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/netplan
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/modprobe.d
36K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/s
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/r
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/w
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/v
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/h
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/d
24K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/m
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/c
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/E
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/p
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/a
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/l
36K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo/x
216K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/terminfo
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/init
12K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/console-setup
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system-sleep
20K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/network
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system-preset
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/rc-local.service.d
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/rescue.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/timers.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/local-fs.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/runlevel3.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/runlevel2.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/multi-user.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/runlevel4.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/runlevel5.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/getty.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/graphical.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/sysinit.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/runlevel1.target.wants
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/sockets.target.wants
8.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system/user@.service.d
712K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system
188K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system-generators
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd/system-shutdown
5.9M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/systemd
176K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/udev/rules.d
2.9M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/udev/hwdb.d
3.2M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/udev
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/lsb/init-functions.d
32K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib/lsb
19M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/srv
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/ai2esb
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/var
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/mnt
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/home/ubuntu/.cache
16K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/home/ubuntu/.ssh
44K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/home/ubuntu
48K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/home
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/lib64
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/tmp/.Test-unix
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/tmp/.font-unix
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/tmp/.XIM-unix
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/tmp/.X11-unix
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/tmp/.ICE-unix
24K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs/tmp
30M /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2AIDevel/rootfs
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2Web2
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2GitLab
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/ai2Base
4.0K /var/snap/lxd/common/lxd/storage-pools/default/containers/raves
4.0K /var/snap/lxd/common/lxd/storage-pools/default/images
So doesn’t look like its all copied over. Only 30MB.
