Ok, sounds like you can just run lxc storage delete default
then and things should be back to normal.
Thanks, Graber, you saved my night.
Appreciate your help.
I did this, but LXD failed to start:
sudo /snap/bin/lxd --debug --group lxd
INFO[11-15|10:24:05] LXD is starting mode=normal path=/var/snap/lxd/common/lxd version=4.20
INFO[11-15|10:24:05] Kernel uid/gid map:
INFO[11-15|10:24:05] - u 0 0 4294967295
INFO[11-15|10:24:05] - g 0 0 4294967295
INFO[11-15|10:24:05] Configured LXD uid/gid map:
INFO[11-15|10:24:05] - u 0 1000000 1000000000
INFO[11-15|10:24:05] - g 0 1000000 1000000000
INFO[11-15|10:24:05] Kernel features:
INFO[11-15|10:24:05] - closing multiple file descriptors efficiently: no
INFO[11-15|10:24:05] - netnsid-based network retrieval: no
INFO[11-15|10:24:05] - pidfds: no
INFO[11-15|10:24:05] - core scheduling: no
INFO[11-15|10:24:05] - uevent injection: yes
INFO[11-15|10:24:05] - seccomp listener: no
INFO[11-15|10:24:05] - seccomp listener continue syscalls: no
INFO[11-15|10:24:05] - seccomp listener add file descriptors: no
INFO[11-15|10:24:05] - attach to namespaces via pidfds: no
INFO[11-15|10:24:05] - safe native terminal allocation : yes
INFO[11-15|10:24:05] - unprivileged file capabilities: yes
INFO[11-15|10:24:05] - cgroup layout: hybrid
WARN[11-15|10:24:05] - Couldn't find the CGroup hugetlb controller, hugepage limits will be ignored
WARN[11-15|10:24:05] - Couldn't find the CGroup memory swap accounting, swap limits will be ignored
INFO[11-15|10:24:05] - shiftfs support: no
WARN[11-15|10:24:05] Instance type not operational type=virtual-machine driver=qemu err="vhost_vsock kernel module not loaded: Failed to run: modprobe -b vhost_vsock: modprobe: ERROR: could not insert 'vhost_vsock': Device or resource busy"
INFO[11-15|10:24:05] Initializing local database
DBUG[11-15|10:24:06] Refreshing local trusted certificate cache
INFO[11-15|10:24:06] Set client certificate to server certificate fingerprint=064e44c7146c763b039f0c043750d89b0f754b76a6c24316cd020e44606bf3d4
DBUG[11-15|10:24:06] Initializing database gateway
INFO[11-15|10:24:06] Starting database node id=1 address=1 role=voter
INFO[11-15|10:24:06] Starting /dev/lxd handler:
INFO[11-15|10:24:06] - binding devlxd socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[11-15|10:24:06] REST API daemon:
INFO[11-15|10:24:06] - binding Unix socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[11-15|10:24:06] Initializing global database
INFO[11-15|10:24:06] Connecting to global database
DBUG[11-15|10:24:06] Dqlite: attempt 1: server 1: connected
INFO[11-15|10:24:06] Connected to global database
INFO[11-15|10:24:06] Initialized global database
DBUG[11-15|10:24:06] Firewall detected "nftables" incompatibility: Kernel version does not meet minimum requirement of 5.2
DBUG[11-15|10:24:06] Firewall detected "xtables" incompatibility: Backend command "ebtables" is an nftables shim
WARN[11-15|10:24:06] Firewall failed to detect any compatible driver, falling back to "xtables" (but some features may not work as expected due to: Backend command "ebtables" is an nftables shim)
INFO[11-15|10:24:06] Firewall loaded driver driver=xtables
INFO[11-15|10:24:06] Initializing storage pools
DBUG[11-15|10:24:06] Initializing and checking storage pool pool=default
DBUG[11-15|10:24:06] Mount started driver=zfs pool=default
DBUG[11-15|10:24:06] Mount finished driver=zfs pool=default
DBUG[11-15|10:24:06] Initializing and checking storage pool pool=lxd
DBUG[11-15|10:24:06] Mount started driver=zfs pool=lxd
DBUG[11-15|10:24:06] Mount finished driver=zfs pool=lxd
EROR[11-15|10:24:06] Failed to start the daemon err="Failed initializing storage pool \"lxd\": ZFS zpool exists but dataset is missing"
INFO[11-15|10:24:06] Starting shutdown sequence signal=interrupt
DBUG[11-15|10:24:06] Cancel ongoing or future gRPC connection attempts
INFO[11-15|10:24:06] Closing the database
INFO[11-15|10:24:06] Stop database gateway
INFO[11-15|10:24:06] Stopping REST API handler:
INFO[11-15|10:24:06] - closing socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[11-15|10:24:06] Stopping /dev/lxd handler:
INFO[11-15|10:24:06] - closing socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[11-15|10:24:06] Unmounting temporary filesystems
INFO[11-15|10:24:06] Done unmounting temporary filesystems
INFO[11-15|10:24:06] Daemon stopped
Error: Failed initializing storage pool "lxd": ZFS zpool exists but dataset is missing
My container zpool was default (before I created the lxd pool manually):
$ sudo zpool list
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
default 46,5G 9,15G 37,3G - 28% 19% 1.00x ONLINE -
lxd 1008M 684K 1007M - 0% 0% 1.00x ONLINE -
but for some reason, lxd tried to load the lxd pool but have failed since it did not exist.
I tried removing rows from /var/snap/lxd/common/lxd/database/global/db.bin in tables storage_pools_config and storage_pools where the lxd pool was mentionned, with no success as lxd adds them again at boot.
Any clue?
Thank you,
