Yes, this big file seems like backup and its time is exactly when I was doing upgrade
root@jp-laptop:~# ls -lh /var/lib/snapd/snapshots/
razem 3,2G
-rw------- 1 root root 851 kwi 28 09:06 10_gnome-characters_v3.32.1+git4.e06f0b2_495.zip
-rw------- 1 root root 832 kwi 28 09:06 11_gnome-logs_3.34.0_93.zip
-rw------- 1 root root 20K kwi 24 21:29 6_bitwarden_1.17.2_24.zip
-rw------- 1 root root 3,2G kwi 24 21:43 7_lxd_4.0.1_14804.zip
-rw------- 1 root root 44K kwi 28 09:06 9_gnome-calculator_3.36.0+git4.51b0dc05_730.zip
stgraber
(Stéphane Graber)
April 28, 2020, 1:46pm
22
Ok, so maybe you’ll get lucky then.
Is it a problem if your two working containers go back in time to when that backup was made?
stgraber
(Stéphane Graber)
April 28, 2020, 1:48pm
23
Can you get the archive.tgz
out of the lxd backup and then run tar ztvf archive.tgz
to see what’s in there?
No problem, I’m just working two days with new system and I want to use these two containers which gone
stgraber
(Stéphane Graber)
April 28, 2020, 1:51pm
25
I’m just hoping the backup is usable… snapd effectively made a tarball of a loop disk while it was in use, there’s good potential for this to not have gone well, but let’s see if we’re lucky.
root@jp-laptop:~/tmp# tar tzvf archive.tgz | head -n40
drwxr-xr-x root/root 0 2018-05-15 17:49 14804/
drwxr-xr-x root/root 0 2020-04-24 17:10 common/
-rw-r--r-- root/root 5 2020-04-24 17:10 common/lxd.pid
-rw-r--r-- root/root 0 2020-04-24 17:10 common/state
drwx--x--x root/root 0 2020-04-24 21:02 common/lxd/
drwx--x--x root/root 0 2020-04-21 17:00 common/lxd/devices/
drwx--x--x root/root 0 2019-05-08 16:14 common/lxd/devices/jp-u1804/
drwx--x--x root/root 0 2020-01-10 11:11 common/lxd/devices/jp-pss/
drwx--x--x root/root 0 2020-04-21 17:00 common/lxd/devices/j2004/
drwx--x--x root/root 0 2020-04-22 17:10 common/lxd/devices/gui1804/
drwx------ root/root 0 2018-05-15 17:49 common/lxd/disks/
drwx------ root/root 0 2020-01-24 15:28 common/lxd/virtual-machines-snapshots/
drwx------ root/root 0 2020-04-24 17:10 common/lxd/logs/
-rw-r--r-- root/root 917 2020-04-21 12:38 common/lxd/logs/lxd.log.7.gz
-rw-r--r-- root/root 3796 2020-04-24 18:06 common/lxd/logs/lxd.log
-rw-r--r-- root/root 8790 2020-04-24 17:10 common/lxd/logs/lxd.log.1
-rw-r--r-- root/root 1295 2020-04-23 08:32 common/lxd/logs/lxd.log.4.gz
etc...
stgraber
(Stéphane Graber)
April 28, 2020, 1:53pm
27
Hmm, this is a bit confusing as it suggests there’s nothing in the disk/
directory and not much usage below that, that’s very odd.
Can you show lxc storage show default
root@jp-laptop:~/tmp# lxc storage show default
source: default
volatile.initial_source: /dev/sda2
zfs.pool_name: default
driver: zfs
- /1.0/containers/gui1804
- /1.0/containers/j2004
- /1.0/containers/jp-pss
- /1.0/containers/jp-u1804
- /1.0/containers/jp-u1804/snapshots/snapsh-po_qhm
- /1.0/images/f71e76edd33548e6c898fad9778997f84d494ad779761ce34826c41031c151fc
- /1.0/profiles/default
status: Created
locations:
- none
stgraber
(Stéphane Graber)
April 28, 2020, 2:08pm
29
Ah cool, so it’s on a dedicated partition, that’s good news.
stgraber
(Stéphane Graber)
April 28, 2020, 2:09pm
30
In that listing you cut off above, does it list all the files for the two lost containers?
There are about 482 files from common/[lxd|lxc] directories
stgraber
(Stéphane Graber)
April 28, 2020, 2:20pm
32
Can you pastebin the entire list somewhere so I can tell if the backup is in fact useful?
It seems reasonably large, so I’m hopeful but maybe it’s all space used up by images?
The BIG list …
-rw-r--r-- root/root 1312 2020-04-24 08:34 common/lxd/logs/lxd.log.3.gz
-rw-r--r-- root/root 1527 2020-04-22 07:53 common/lxd/logs/lxd.log.6.gz
-rw-r--r-- root/root 1212 2020-04-24 09:00 common/lxd/logs/lxd.log.2.gz
drwxr-xr-x root/root 0 2020-04-24 08:34 common/lxd/logs/jp-u1804-hm42-pss/
-rw-r----- root/root 0 2020-04-24 08:34 common/lxd/logs/jp-u1804/lxc.log
-rw-r----- root/root 2202 2020-03-10 10:07 common/lxd/logs/jp-u1804/lxc.conf
drwxr-xr-x root/root 0 2020-04-24 09:00 common/lxd/logs/jp-pss/
-rw-r----- root/root 640 2020-04-24 09:00 common/lxd/logs/jp-pss/lxc.log.old
-rw-r--r-- root/root 0 2020-04-24 09:00 common/lxd/logs/jp-pss/forkstart.log
-rw-r--r-- root/root 0 2020-04-23 15:01 common/lxd/logs/jp-pss/forkexec.log
-rw-r----- root/root 795 2020-04-24 16:58 common/lxd/logs/jp-pss/lxc.log
-rw------- root/root 39797 2020-04-24 16:58 common/lxd/logs/jp-pss/console.log
-rw-r----- root/root 2371 2020-04-24 09:00 common/lxd/logs/jp-pss/lxc.conf
drwxr-xr-x root/root 0 2020-04-24 09:00 common/lxd/logs/j2004/
-rw-r----- root/root 586 2020-04-24 09:00 common/lxd/logs/j2004/lxc.log.old
-rw-r--r-- root/root 0 2020-04-24 09:00 common/lxd/logs/j2004/forkstart.log
-rw-r----- root/root 586 2020-04-24 09:04 common/lxd/logs/j2004/lxc.log
-rw------- root/root 7848 2020-04-24 09:04 common/lxd/logs/j2004/console.log
-rw-r----- root/root 2227 2020-04-24 09:00 common/lxd/logs/j2004/lxc.conf
-rw-r--r-- root/root 1058 2020-04-22 13:03 common/lxd/logs/lxd.log.5.gz
drwxr-xr-x root/root 0 2020-04-24 17:10 common/lxd/logs/gui1804/
-rw-r----- root/root 0 2020-04-24 17:10 common/lxd/logs/gui1804/lxc.log
-rw------- root/root 17565 2020-04-22 17:10 common/lxd/logs/gui1804/console.log
-rw-r----- root/root 4321 2020-04-22 13:03 common/lxd/logs/gui1804/lxc.conf
drwxr-xr-x root/root 0 2018-05-15 17:49 common/lxd/devlxd/
drwx--x--x root/root 0 2020-01-24 15:28 common/lxd/virtual-machines/
drwx------ root/root 0 2020-04-21 16:59 common/lxd/cache/
-rw------- root/root 173750 2019-08-05 07:42 common/lxd/cache/simplestreams.yaml
drwxr-xr-x root/root 0 2020-04-24 17:10 common/lxd/cache/64bfbd0d406818492958140cedfac3be5f9cce7fd130ca14fa2cd586a2b6842e/
-rw-r--r-- root/root 9286 2020-04-24 17:10 common/lxd/cache/64bfbd0d406818492958140cedfac3be5f9cce7fd130ca14fa2cd586a2b6842e/index.json
-rw-r--r-- root/root 1241835 2020-04-24 17:10 common/lxd/cache/64bfbd0d406818492958140cedfac3be5f9cce7fd130ca14fa2cd586a2b6842e/images.json
-rw------- root/root 6179 2020-04-24 17:10 common/lxd/cache/instance_types.yaml
drwx------ root/root 0 2020-03-24 13:05 common/lxd/database/
drwxr-x--- root/root 0 2020-04-24 18:06 common/lxd/database/global/
-rw------- root/root 355440 2019-10-04 16:40 common/lxd/database/global/12717-12751
-rw------- root/root 214752 2019-10-08 16:42 common/lxd/database/global/12814-12832
-rw------- root/root 227352 2019-09-09 13:38 common/lxd/database/global/11786-11808
-rw------- root/root 363648 2020-02-07 15:38 common/lxd/database/global/0000000000015945-0000000000015979
-rw------- root/root 388272 2020-03-02 08:16 common/lxd/database/global/0000000000016681-0000000000016715
-rw------- root/root 169464 2020-03-24 13:13 common/lxd/database/global/0000000000017768-0000000000017784
-rw------- root/root 404832 2020-02-21 17:57 common/lxd/database/global/0000000000016467-0000000000016503
-rw------- root/root 219048 2019-07-24 18:10 common/lxd/database/global/11111-11132
-rw------- root/root 247944 2020-03-27 13:29 common/lxd/database/global/0000000000017944-0000000000017967
-rw------- root/root 56 2020-03-27 15:30 common/lxd/database/global/snapshot-100-17986-24639372.meta
-rw------- root/root 169464 2020-04-11 13:39 common/lxd/database/global/0000000000018581-0000000000018597
-rw------- root/root 355416 2020-02-04 15:57 common/lxd/database/global/0000000000015795-0000000000015829
-rw------- root/root 446304 2020-02-20 17:01 common/lxd/database/global/0000000000016390-0000000000016432
-rw------- root/root 2238880 2020-03-27 15:30 common/lxd/database/global/snapshot-100-17986-24639372
-rw------- root/root 367752 2020-03-17 15:47 common/lxd/database/global/0000000000017350-0000000000017384
-rw------- root/root 32 2020-01-24 08:43 common/lxd/database/global/metadata2
-rw------- root/root 355488 2019-10-18 16:32 common/lxd/database/global/13119-13154
-rw------- root/root 380208 2020-04-07 17:33 common/lxd/database/global/0000000000018450-0000000000018486
-rw------- root/root 425640 2020-02-06 16:46 common/lxd/database/global/0000000000015904-0000000000015944
-rw------- root/root 289344 2019-10-25 17:18 common/lxd/database/global/13289-13317
-rw------- root/root 169464 2019-11-05 09:36 common/lxd/database/global/13468-13484
-rw------- root/root 372000 2019-09-20 11:57 common/lxd/database/global/12123-12159
-rw------- root/root 334776 2019-10-23 15:11 common/lxd/database/global/13225-13257
-rw------- root/root 541464 2019-11-07 16:13 common/lxd/database/global/13516-13569
-rw------- root/root 239664 2020-03-19 17:28 common/lxd/database/global/0000000000017542-0000000000017564
-rw------- root/root 648480 2020-04-23 17:26 common/lxd/database/global/0000000000019021-0000000000019078
-rw------- root/root 231456 2019-09-02 16:40 common/lxd/database/global/11649-11671
-rw------- root/root 334704 2020-02-18 16:24 common/lxd/database/global/0000000000016300-0000000000016331
-rw------- root/root 508296 2020-03-12 17:20 common/lxd/database/global/0000000000017173-0000000000017221
-rw------- root/root 219072 2020-03-17 19:34 common/lxd/database/global/0000000000017407-0000000000017428
-rw------- root/root 285240 2020-04-15 18:09 common/lxd/database/global/0000000000018638-0000000000018666
-rw------- root/root 751872 2020-04-09 17:16 common/lxd/database/global/0000000000018512-0000000000018580
-rw------- root/root 355440 2019-11-15 17:27 common/lxd/database/global/13683-13717
-rw------- root/root 1243992 2019-09-25 18:31 common/lxd/database/global/12187-12307
-rw------- root/root 310008 2019-10-24 16:35 common/lxd/database/global/13258-13288
-rw------- root/root 1016688 2020-01-08 18:42 common/lxd/database/global/14837-14935
-rw------- root/root 285240 2020-04-16 16:13 common/lxd/database/global/0000000000018704-0000000000018732
-rw------- root/root 152976 2020-03-19 17:22 common/lxd/database/global/0000000000017526-0000000000017541
-rw------- root/root 425712 2019-09-16 21:19 common/lxd/database/global/11985-12026
-rw------- root/root 673608 2020-03-20 16:59 common/lxd/database/global/0000000000017565-0000000000017629
-rw------- root/root 400872 2020-02-17 16:20 common/lxd/database/global/0000000000016261-0000000000016299
-rw------- root/root 557976 2019-11-05 09:23 common/lxd/database/global/13413-13467
-rw------- root/root 376032 2020-04-17 13:52 common/lxd/database/global/0000000000018733-0000000000018768
-rw------- root/root 289344 2019-11-18 17:11 common/lxd/database/global/13718-13746
-rw------- root/root 310008 2019-12-27 17:04 common/lxd/database/global/14707-14737
-rw------- root/root 32 2020-01-24 08:43 common/lxd/database/global/metadata1
-rw------- root/root 891912 2020-04-21 19:15 common/lxd/database/global/0000000000018873-0000000000018948
-rw------- root/root 272784 2019-09-20 17:25 common/lxd/database/global/12160-12186
-rw------- root/root 272784 2019-11-25 14:28 common/lxd/database/global/13878-13904
-rw------- root/root 272712 2020-03-18 13:19 common/lxd/database/global/0000000000017429-0000000000017454
-rw------- root/root 528960 2020-02-13 15:56 common/lxd/database/global/0000000000016170-0000000000016220
-rw------- root/root 289056 2020-04-06 18:43 common/lxd/database/global/0000000000018425-0000000000018449
-rw------- root/root 343056 2020-04-17 16:52 common/lxd/database/global/0000000000018769-0000000000018802
-rw------- root/root 56 2020-04-22 17:10 common/lxd/database/global/snapshot-100-19010-33437991.meta
-rw------- root/root 400920 2020-02-14 16:49 common/lxd/database/global/0000000000016221-0000000000016260
-rw------- root/root 355440 2019-10-30 17:46 common/lxd/database/global/13378-13412
-rw------- root/root 252120 2019-12-24 12:56 common/lxd/database/global/14665-14689
-rw------- root/root 305472 2020-02-24 12:35 common/lxd/database/global/0000000000016504-0000000000016528
-rw------- root/root 355440 2019-10-22 16:35 common/lxd/database/global/13190-13224
-rw------- root/root 169464 2019-12-30 07:51 common/lxd/database/global/14766-14782
-rw------- root/root 355440 2019-12-02 18:01 common/lxd/database/global/14063-14097
-rw------- root/root 310008 2019-11-08 17:14 common/lxd/database/global/13570-13600
-rw------- root/root 214896 2020-03-24 13:05 common/lxd/database/global/0000000000017725-0000000000017745
-rw------- root/root 310008 2019-12-06 18:17 common/lxd/database/global/14228-14258
-rw------- root/root 549624 2020-01-20 17:00 common/lxd/database/global/15446-15498
-rw------- root/root 334776 2019-10-05 19:34 common/lxd/database/global/12752-12784
-rw------- root/root 409080 2020-03-26 17:16 common/lxd/database/global/0000000000017891-0000000000017929
-rw------- root/root 1169544 2020-01-15 16:33 common/lxd/database/global/15252-15364
-rw------- root/root 169536 2019-08-13 16:04 common/lxd/database/global/11606-11623
-rw------- root/root 169464 2020-03-24 13:15 common/lxd/database/global/0000000000017785-0000000000017801
-rw------- root/root 219000 2020-04-21 12:38 common/lxd/database/global/0000000000018852-0000000000018872
-rw------- root/root 260328 2019-09-02 13:31 common/lxd/database/global/11624-11648
-rw------- root/root 830712 2019-09-05 18:35 common/lxd/database/global/11672-11752
-rw------- root/root 231384 2020-03-24 13:12 common/lxd/database/global/0000000000017746-0000000000017767
-rw------- root/root 355440 2019-11-26 16:32 common/lxd/database/global/13905-13939
-rw------- root/root 132312 2020-04-24 18:06 common/lxd/database/global/0000000000019166-0000000000019179
-rw------- root/root 227352 2019-12-31 15:29 common/lxd/database/global/14814-14836
-rw------- root/root 310008 2019-12-13 18:18 common/lxd/database/global/14457-14487
-rw------- root/root 322392 2020-03-30 17:56 common/lxd/database/global/0000000000018024-0000000000018055
-rw------- root/root 169464 2019-10-11 09:05 common/lxd/database/global/12888-12904
-rw------- root/root 239664 2020-03-31 08:49 common/lxd/database/global/0000000000018056-0000000000018078
-rw------- root/root 310008 2019-07-30 17:24 common/lxd/database/global/11220-11250
-rw------- root/root 355440 2019-10-21 17:53 common/lxd/database/global/13155-13189
-rw------- root/root 404544 2020-03-13 18:46 common/lxd/database/global/0000000000017257-0000000000017289
-rw------- root/root 289344 2019-10-14 16:39 common/lxd/database/global/12953-12981
-rw------- root/root 838704 2020-04-06 06:33 common/lxd/database/global/0000000000018307-0000000000018384
-rw------- root/root 252120 2019-10-17 16:32 common/lxd/database/global/13094-13118
-rw------- root/root 351336 2019-12-18 19:02 common/lxd/database/global/14550-14584
-rw------- root/root 264504 2020-02-03 15:18 common/lxd/database/global/0000000000015745-0000000000015770
-rw------- root/root 210792 2019-08-02 16:37 common/lxd/database/global/11340-11360
-rw------- root/root 124032 2019-10-14 17:38 common/lxd/database/global/12982-12994
-rw------- root/root 508296 2020-04-20 16:18 common/lxd/database/global/0000000000018803-0000000000018851
-rw------- root/root 132312 2020-03-26 18:03 common/lxd/database/global/0000000000017930-0000000000017943
-rw------- root/root 280920 2020-04-24 09:00 common/lxd/database/global/0000000000019079-0000000000019104
-rw------- root/root 256224 2020-04-08 13:05 common/lxd/database/global/0000000000018487-0000000000018511
-rw------- root/root 214896 2019-07-23 12:16 common/lxd/database/global/10943-10963
-rw------- root/root 210840 2020-03-17 18:02 common/lxd/database/global/0000000000017385-0000000000017406
-rw------- root/root 421888 2020-04-24 18:06 common/lxd/database/global/db.bin
-rw------- root/root 570288 2020-01-21 15:41 common/lxd/database/global/15499-15553
-rw------- root/root 293480 2019-07-18 21:59 common/lxd/database/global/10819-10847
-rw------- root/root 413328 2019-10-29 15:57 common/lxd/database/global/13337-13377
-rw------- root/root 334776 2019-11-14 15:32 common/lxd/database/global/13650-13682
-rw------- root/root 169464 2020-03-24 10:22 common/lxd/database/global/0000000000017708-0000000000017724
-rw------- root/root 169464 2019-12-27 08:57 common/lxd/database/global/14690-14706
-rw------- root/root 310008 2019-07-31 16:38 common/lxd/database/global/11251-11281
-rw------- root/root 330672 2019-12-16 15:31 common/lxd/database/global/14488-14520
-rw------- root/root 619968 2019-08-13 13:46 common/lxd/database/global/11545-11605
-rw------- root/root 1347312 2019-11-22 16:16 common/lxd/database/global/13747-13877
-rw------- root/root 388416 2020-03-19 15:50 common/lxd/database/global/0000000000017489-0000000000017525
-rw------- root/root 314112 2019-11-05 16:32 common/lxd/database/global/13485-13515
-rw------- root/root 495984 2019-12-20 16:58 common/lxd/database/global/14585-14633
-rw------- root/root 297624 2020-03-27 19:53 common/lxd/database/global/0000000000017968-0000000000017997
-rw------- root/root 652992 2020-04-01 18:30 common/lxd/database/global/0000000000018152-0000000000018215
-rw------- root/root 3924384 2020-01-13 09:23 common/lxd/database/global/14967-15208
-rw------- root/root 2014712 2020-04-24 18:06 common/lxd/database/global/db.bin-wal
-rw------- root/root 268728 2019-12-28 13:40 common/lxd/database/global/14738-14765
-rw------- root/root 442200 2020-01-14 08:27 common/lxd/database/global/15209-15251
-rw------- root/root 772752 2020-03-11 17:32 common/lxd/database/global/0000000000017099-0000000000017172
-rw------- root/root 524856 2020-02-06 07:40 common/lxd/database/global/0000000000015853-0000000000015903
-rw------- root/root 950592 2019-10-02 16:56 common/lxd/database/global/12594-12686
-rw------- root/root 243840 2020-02-03 18:13 common/lxd/database/global/0000000000015771-0000000000015794
-rw------- root/root 310008 2019-08-01 16:31 common/lxd/database/global/11282-11312
-rw------- root/root 334776 2019-09-06 16:10 common/lxd/database/global/11753-11785
-rw------- root/root 301656 2020-03-31 23:16 common/lxd/database/global/0000000000018123-0000000000018151
-rw------- root/root 1640112 2019-08-08 17:49 common/lxd/database/global/11394-11544
-rw------- root/root 586760 2020-04-22 17:10 common/lxd/database/global/snapshot-100-19010-33437991
-rw------- root/root 297552 2020-03-31 17:19 common/lxd/database/global/0000000000018079-0000000000018107
-rw------- root/root 487680 2020-01-17 16:40 common/lxd/database/global/15398-15445
-rw------- root/root 958776 2020-02-26 15:19 common/lxd/database/global/0000000000016529-0000000000016621
-rw------- root/root 1012584 2019-10-17 11:43 common/lxd/database/global/12995-13093
-rw------- root/root 392592 2019-07-22 16:18 common/lxd/database/global/10905-10942
-rw------- root/root 1322472 2020-01-24 08:43 common/lxd/database/global/15554-15681
-rw------- root/root 301368 2020-01-24 16:15 common/lxd/database/global/0000000000015720-0000000000015744
-rw------- root/root 413256 2020-04-06 17:54 common/lxd/database/global/0000000000018385-0000000000018424
-rw------- root/root 1143336 2019-07-23 17:03 common/lxd/database/global/10964-11054
-rw------- root/root 376104 2019-09-18 17:52 common/lxd/database/global/12086-12122
-rw------- root/root 466968 2020-02-12 17:40 common/lxd/database/global/0000000000016125-0000000000016169
-rw------- root/root 442200 2020-03-26 07:34 common/lxd/database/global/0000000000017848-0000000000017890
-rw------- root/root 409128 2020-04-15 16:59 common/lxd/database/global/0000000000018598-0000000000018637
-rw------- root/root 467016 2020-03-24 19:52 common/lxd/database/global/0000000000017802-0000000000017847
-rw------- root/root 656760 2020-02-27 19:26 common/lxd/database/global/0000000000016622-0000000000016680
-rw------- root/root 289344 2019-10-11 16:06 common/lxd/database/global/12905-12933
-rw------- root/root 268680 2019-08-02 14:29 common/lxd/database/global/11313-11339
-rw------- root/root 388416 2020-04-16 14:49 common/lxd/database/global/0000000000018667-0000000000018703
-rw------- root/root 495672 2020-04-22 17:10 common/lxd/database/global/0000000000018976-0000000000019020
-rw------- root/root 466968 2020-03-16 18:27 common/lxd/database/global/0000000000017290-0000000000017334
-rw------- root/root 1248096 2020-02-11 19:18 common/lxd/database/global/0000000000016004-0000000000016124
-rw------- root/root 355440 2019-07-25 16:30 common/lxd/database/global/11133-11167
-rw------- root/root 909312 2019-09-14 15:35 common/lxd/database/global/11895-11984
-rw------- root/root 338952 2020-03-18 19:46 common/lxd/database/global/0000000000017455-0000000000017488
-rw------- root/root 169464 2020-03-23 07:41 common/lxd/database/global/0000000000017630-0000000000017646
-rw------- root/root 603408 2019-09-17 16:15 common/lxd/database/global/12027-12085
-rw------- root/root 562080 2019-10-10 17:35 common/lxd/database/global/12833-12887
-rw------- root/root 157152 2020-02-18 17:54 common/lxd/database/global/0000000000016332-0000000000016348
-rw------- root/root 446304 2020-04-02 17:50 common/lxd/database/global/0000000000018233-0000000000018275
-rw------- root/root 495984 2019-11-13 19:08 common/lxd/database/global/13601-13649
-rw------- root/root 289344 2019-12-17 17:07 common/lxd/database/global/14521-14549
-rw------- root/root 2938488 2019-09-30 18:06 common/lxd/database/global/12308-12593
-rw------- root/root 223248 2020-02-04 16:34 common/lxd/database/global/0000000000015830-0000000000015852
-rw------- root/root 310008 2019-12-30 16:01 common/lxd/database/global/14783-14813
-rw------- root/root 310008 2019-12-23 16:03 common/lxd/database/global/14634-14664
-rw------- root/root 999336 2019-09-12 16:42 common/lxd/database/global/11809-11894
-rw------- root/root 338880 2019-07-29 16:52 common/lxd/database/global/11187-11219
-rw------- root/root 268608 2020-03-30 13:08 common/lxd/database/global/0000000000017998-0000000000018023
-rw------- root/root 186024 2019-07-29 12:39 common/lxd/database/global/11168-11186
-rw------- root/root 243840 2020-02-07 17:06 common/lxd/database/global/0000000000015980-0000000000016003
-rw------- root/root 310008 2019-11-29 17:12 common/lxd/database/global/14032-14062
-rw------- root/root 632280 2020-03-23 19:09 common/lxd/database/global/0000000000017647-0000000000017707
-rw------- root/root 338880 2020-01-16 15:30 common/lxd/database/global/15365-15397
-rw------- root/root 318216 2020-04-03 13:39 common/lxd/database/global/0000000000018276-0000000000018306
-rw------- root/root 681528 2020-04-24 16:58 common/lxd/database/global/0000000000019105-0000000000019165
-rw------- root/root 3801840 2020-03-10 10:04 common/lxd/database/global/0000000000016716-0000000000017079
-rw------- root/root 2045688 2019-12-12 16:33 common/lxd/database/global/14259-14456
-rw------- root/root 289392 2019-10-03 16:34 common/lxd/database/global/12687-12716
-rw------- root/root 351192 2019-08-05 14:30 common/lxd/database/global/11361-11393
-rw------- root/root 32768 2018-08-20 07:50 common/lxd/database/global/db.bin-shm
-rw------- root/root 425640 2020-02-19 16:16 common/lxd/database/global/0000000000016349-0000000000016389
-rw------- root/root 186024 2019-10-28 12:05 common/lxd/database/global/13318-13336
-rw------- root/root 396696 2020-01-24 15:28 common/lxd/database/global/15682-15719
-rw------- root/root 820704 2019-07-24 16:14 common/lxd/database/global/11055-11110
-rw------- root/root 355368 2020-02-21 15:34 common/lxd/database/global/0000000000016433-0000000000016466
-rw------- root/root 310008 2020-01-09 16:23 common/lxd/database/global/14936-14966
-rw------- root/root 289344 2019-10-08 16:00 common/lxd/database/global/12785-12813
-rw------- root/root 206544 2020-03-10 10:07 common/lxd/database/global/0000000000017080-0000000000017098
-rw------- root/root 310008 2019-12-04 08:23 common/lxd/database/global/14098-14128
-rw------- root/root 173568 2020-04-01 21:39 common/lxd/database/global/0000000000018216-0000000000018232
-rw------- root/root 929976 2019-11-28 16:28 common/lxd/database/global/13940-14031
-rw------- root/root 285096 2020-04-22 13:03 common/lxd/database/global/0000000000018949-0000000000018975
-rw------- root/root 190128 2019-10-11 17:39 common/lxd/database/global/12934-12952
-rw------- root/root 363648 2020-03-13 15:26 common/lxd/database/global/0000000000017222-0000000000017256
-rw------- root/root 1016688 2019-12-05 17:36 common/lxd/database/global/14129-14227
-rw------- root/root 144696 2020-03-31 18:26 common/lxd/database/global/0000000000018108-0000000000018122
-rw------- root/root 152904 2020-03-16 22:37 common/lxd/database/global/0000000000017335-0000000000017349
-rw------- root/root 578640 2019-07-19 17:02 common/lxd/database/global/10848-10904
drwxr-x--- root/root 0 2020-03-24 13:05 common/lxd/database/global.bak/
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/12717-12751
-rw-r--r-- root/root 214752 2020-03-24 13:05 common/lxd/database/global.bak/12814-12832
-rw-r--r-- root/root 227352 2020-03-24 13:05 common/lxd/database/global.bak/11786-11808
-rw-r--r-- root/root 363648 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015945-0000000000015979
-rw-r--r-- root/root 388272 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016681-0000000000016715
-rw-r--r-- root/root 404832 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016467-0000000000016503
-rw-r--r-- root/root 219048 2020-03-24 13:05 common/lxd/database/global.bak/11111-11132
-rw-r--r-- root/root 355416 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015795-0000000000015829
-rw-r--r-- root/root 446304 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016390-0000000000016432
-rw-r--r-- root/root 367752 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017350-0000000000017384
-rw-r--r-- root/root 32 2020-03-24 13:05 common/lxd/database/global.bak/metadata2
-rw-r--r-- root/root 355488 2020-03-24 13:05 common/lxd/database/global.bak/13119-13154
-rw-r--r-- root/root 8388608 2020-03-24 13:05 common/lxd/database/global.bak/open-1
-rw-r--r-- root/root 425640 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015904-0000000000015944
-rw-r--r-- root/root 289344 2020-03-24 13:05 common/lxd/database/global.bak/13289-13317
-rw-r--r-- root/root 169464 2020-03-24 13:05 common/lxd/database/global.bak/13468-13484
-rw-r--r-- root/root 372000 2020-03-24 13:05 common/lxd/database/global.bak/12123-12159
-rw-r--r-- root/root 334776 2020-03-24 13:05 common/lxd/database/global.bak/13225-13257
-rw-r--r-- root/root 541464 2020-03-24 13:05 common/lxd/database/global.bak/13516-13569
-rw-r--r-- root/root 239664 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017542-0000000000017564
-rw-r--r-- root/root 231456 2020-03-24 13:05 common/lxd/database/global.bak/11649-11671
-rw-r--r-- root/root 334704 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016300-0000000000016331
-rw-r--r-- root/root 508296 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017173-0000000000017221
-rw-r--r-- root/root 219072 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017407-0000000000017428
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/13683-13717
-rw-r--r-- root/root 1243992 2020-03-24 13:05 common/lxd/database/global.bak/12187-12307
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/13258-13288
-rw-r--r-- root/root 1016688 2020-03-24 13:05 common/lxd/database/global.bak/14837-14935
-rw-r--r-- root/root 152976 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017526-0000000000017541
-rw-r--r-- root/root 425712 2020-03-24 13:05 common/lxd/database/global.bak/11985-12026
-rw-r--r-- root/root 673608 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017565-0000000000017629
-rw-r--r-- root/root 400872 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016261-0000000000016299
-rw-r--r-- root/root 557976 2020-03-24 13:05 common/lxd/database/global.bak/13413-13467
-rw-r--r-- root/root 289344 2020-03-24 13:05 common/lxd/database/global.bak/13718-13746
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14707-14737
-rw-r--r-- root/root 32 2020-03-24 13:05 common/lxd/database/global.bak/metadata1
-rw-r--r-- root/root 272784 2020-03-24 13:05 common/lxd/database/global.bak/12160-12186
-rw-r--r-- root/root 272784 2020-03-24 13:05 common/lxd/database/global.bak/13878-13904
-rw-r--r-- root/root 272712 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017429-0000000000017454
-rw-r--r-- root/root 528960 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016170-0000000000016220
-rw-r--r-- root/root 8388608 2020-03-24 13:05 common/lxd/database/global.bak/open-2
-rw-r--r-- root/root 1596160 2020-03-24 13:05 common/lxd/database/global.bak/snapshot-100-15938-25222714
-rw-r--r-- root/root 56 2020-03-24 13:05 common/lxd/database/global.bak/snapshot-100-16962-324031899.meta
-rw-r--r-- root/root 400920 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016221-0000000000016260
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/13378-13412
-rw-r--r-- root/root 252120 2020-03-24 13:05 common/lxd/database/global.bak/14665-14689
-rw-r--r-- root/root 305472 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016504-0000000000016528
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/13190-13224
-rw-r--r-- root/root 169464 2020-03-24 13:05 common/lxd/database/global.bak/14766-14782
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/14063-14097
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/13570-13600
-rw-r--r-- root/root 214896 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017725-0000000000017745
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14228-14258
-rw-r--r-- root/root 549624 2020-03-24 13:05 common/lxd/database/global.bak/15446-15498
-rw-r--r-- root/root 334776 2020-03-24 13:05 common/lxd/database/global.bak/12752-12784
-rw-r--r-- root/root 1169544 2020-03-24 13:05 common/lxd/database/global.bak/15252-15364
-rw-r--r-- root/root 169536 2020-03-24 13:05 common/lxd/database/global.bak/11606-11623
-rw-r--r-- root/root 260328 2020-03-24 13:05 common/lxd/database/global.bak/11624-11648
-rw-r--r-- root/root 830712 2020-03-24 13:05 common/lxd/database/global.bak/11672-11752
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/13905-13939
-rw-r--r-- root/root 227352 2020-03-24 13:05 common/lxd/database/global.bak/14814-14836
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14457-14487
-rw-r--r-- root/root 169464 2020-03-24 13:05 common/lxd/database/global.bak/12888-12904
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/11220-11250
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/13155-13189
-rw-r--r-- root/root 404544 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017257-0000000000017289
-rw-r--r-- root/root 289344 2020-03-24 13:05 common/lxd/database/global.bak/12953-12981
-rw-r--r-- root/root 252120 2020-03-24 13:05 common/lxd/database/global.bak/13094-13118
-rw-r--r-- root/root 351336 2020-03-24 13:05 common/lxd/database/global.bak/14550-14584
-rw-r--r-- root/root 264504 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015745-0000000000015770
-rw-r--r-- root/root 210792 2020-03-24 13:05 common/lxd/database/global.bak/11340-11360
-rw-r--r-- root/root 124032 2020-03-24 13:05 common/lxd/database/global.bak/12982-12994
-rw-r--r-- root/root 214896 2020-03-24 13:05 common/lxd/database/global.bak/10943-10963
-rw-r--r-- root/root 210840 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017385-0000000000017406
-rw-r--r-- root/root 421888 2020-03-24 13:05 common/lxd/database/global.bak/db.bin
-rw-r--r-- root/root 570288 2020-03-24 13:05 common/lxd/database/global.bak/15499-15553
-rw-r--r-- root/root 293480 2020-03-24 13:05 common/lxd/database/global.bak/10819-10847
-rw-r--r-- root/root 413328 2020-03-24 13:05 common/lxd/database/global.bak/13337-13377
-rw-r--r-- root/root 334776 2020-03-24 13:05 common/lxd/database/global.bak/13650-13682
-rw-r--r-- root/root 169464 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017708-0000000000017724
-rw-r--r-- root/root 169464 2020-03-24 13:05 common/lxd/database/global.bak/14690-14706
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/11251-11281
-rw-r--r-- root/root 330672 2020-03-24 13:05 common/lxd/database/global.bak/14488-14520
-rw-r--r-- root/root 619968 2020-03-24 13:05 common/lxd/database/global.bak/11545-11605
-rw-r--r-- root/root 1347312 2020-03-24 13:05 common/lxd/database/global.bak/13747-13877
-rw-r--r-- root/root 388416 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017489-0000000000017525
-rw-r--r-- root/root 314112 2020-03-24 13:05 common/lxd/database/global.bak/13485-13515
-rw-r--r-- root/root 495984 2020-03-24 13:05 common/lxd/database/global.bak/14585-14633
-rw-r--r-- root/root 3924384 2020-03-24 13:05 common/lxd/database/global.bak/14967-15208
-rw-r--r-- root/root 3493792 2020-03-24 13:05 common/lxd/database/global.bak/db.bin-wal
-rw-r--r-- root/root 268728 2020-03-24 13:05 common/lxd/database/global.bak/14738-14765
-rw-r--r-- root/root 442200 2020-03-24 13:05 common/lxd/database/global.bak/15209-15251
-rw-r--r-- root/root 772752 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017099-0000000000017172
-rw-r--r-- root/root 524856 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015853-0000000000015903
-rw-r--r-- root/root 950592 2020-03-24 13:05 common/lxd/database/global.bak/12594-12686
-rw-r--r-- root/root 243840 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015771-0000000000015794
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/11282-11312
-rw-r--r-- root/root 334776 2020-03-24 13:05 common/lxd/database/global.bak/11753-11785
-rw-r--r-- root/root 1640112 2020-03-24 13:05 common/lxd/database/global.bak/11394-11544
-rw-r--r-- root/root 487680 2020-03-24 13:05 common/lxd/database/global.bak/15398-15445
-rw-r--r-- root/root 958776 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016529-0000000000016621
-rw-r--r-- root/root 1012584 2020-03-24 13:05 common/lxd/database/global.bak/12995-13093
-rw-r--r-- root/root 392592 2020-03-24 13:05 common/lxd/database/global.bak/10905-10942
-rw-r--r-- root/root 1322472 2020-03-24 13:05 common/lxd/database/global.bak/15554-15681
-rw-r--r-- root/root 301368 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015720-0000000000015744
-rw-r--r-- root/root 1143336 2020-03-24 13:05 common/lxd/database/global.bak/10964-11054
-rw-r--r-- root/root 376104 2020-03-24 13:05 common/lxd/database/global.bak/12086-12122
-rw-r--r-- root/root 466968 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016125-0000000000016169
-rw-r--r-- root/root 656760 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016622-0000000000016680
-rw-r--r-- root/root 289344 2020-03-24 13:05 common/lxd/database/global.bak/12905-12933
-rw-r--r-- root/root 268680 2020-03-24 13:05 common/lxd/database/global.bak/11313-11339
-rw-r--r-- root/root 466968 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017290-0000000000017334
-rw-r--r-- root/root 1248096 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016004-0000000000016124
-rw-r--r-- root/root 355440 2020-03-24 13:05 common/lxd/database/global.bak/11133-11167
-rw-r--r-- root/root 909312 2020-03-24 13:05 common/lxd/database/global.bak/11895-11984
-rw-r--r-- root/root 338952 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017455-0000000000017488
-rw-r--r-- root/root 169464 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017630-0000000000017646
-rw-r--r-- root/root 603408 2020-03-24 13:05 common/lxd/database/global.bak/12027-12085
-rw-r--r-- root/root 562080 2020-03-24 13:05 common/lxd/database/global.bak/12833-12887
-rw-r--r-- root/root 157152 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016332-0000000000016348
-rw-r--r-- root/root 495984 2020-03-24 13:05 common/lxd/database/global.bak/13601-13649
-rw-r--r-- root/root 289344 2020-03-24 13:05 common/lxd/database/global.bak/14521-14549
-rw-r--r-- root/root 2938488 2020-03-24 13:05 common/lxd/database/global.bak/12308-12593
-rw-r--r-- root/root 223248 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015830-0000000000015852
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14783-14813
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14634-14664
-rw-r--r-- root/root 999336 2020-03-24 13:05 common/lxd/database/global.bak/11809-11894
-rw-r--r-- root/root 338880 2020-03-24 13:05 common/lxd/database/global.bak/11187-11219
-rw-r--r-- root/root 186024 2020-03-24 13:05 common/lxd/database/global.bak/11168-11186
-rw-r--r-- root/root 243840 2020-03-24 13:05 common/lxd/database/global.bak/0000000000015980-0000000000016003
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14032-14062
-rw-r--r-- root/root 632280 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017647-0000000000017707
-rw-r--r-- root/root 56 2020-03-24 13:05 common/lxd/database/global.bak/snapshot-100-15938-25222714.meta
-rw-r--r-- root/root 338880 2020-03-24 13:05 common/lxd/database/global.bak/15365-15397
-rw-r--r-- root/root 3801840 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016716-0000000000017079
-rw-r--r-- root/root 2045688 2020-03-24 13:05 common/lxd/database/global.bak/14259-14456
-rw-r--r-- root/root 289392 2020-03-24 13:05 common/lxd/database/global.bak/12687-12716
-rw-r--r-- root/root 351192 2020-03-24 13:05 common/lxd/database/global.bak/11361-11393
-rw-r--r-- root/root 32768 2020-03-24 13:05 common/lxd/database/global.bak/db.bin-shm
-rw-r--r-- root/root 425640 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016349-0000000000016389
-rw-r--r-- root/root 186024 2020-03-24 13:05 common/lxd/database/global.bak/13318-13336
-rw-r--r-- root/root 396696 2020-03-24 13:05 common/lxd/database/global.bak/15682-15719
-rw-r--r-- root/root 8388608 2020-03-24 13:05 common/lxd/database/global.bak/open-3
-rw-r--r-- root/root 820704 2020-03-24 13:05 common/lxd/database/global.bak/11055-11110
-rw-r--r-- root/root 355368 2020-03-24 13:05 common/lxd/database/global.bak/0000000000016433-0000000000016466
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14936-14966
-rw-r--r-- root/root 289344 2020-03-24 13:05 common/lxd/database/global.bak/12785-12813
-rw-r--r-- root/root 4055800 2020-03-24 13:05 common/lxd/database/global.bak/snapshot-100-16962-324031899
-rw-r--r-- root/root 206544 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017080-0000000000017098
-rw-r--r-- root/root 310008 2020-03-24 13:05 common/lxd/database/global.bak/14098-14128
-rw-r--r-- root/root 929976 2020-03-24 13:05 common/lxd/database/global.bak/13940-14031
-rw-r--r-- root/root 190128 2020-03-24 13:05 common/lxd/database/global.bak/12934-12952
-rw-r--r-- root/root 363648 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017222-0000000000017256
-rw-r--r-- root/root 1016688 2020-03-24 13:05 common/lxd/database/global.bak/14129-14227
-rw-r--r-- root/root 152904 2020-03-24 13:05 common/lxd/database/global.bak/0000000000017335-0000000000017349
-rw-r--r-- root/root 578640 2020-03-24 13:05 common/lxd/database/global.bak/10848-10904
-rw-r--r-- root/root 40960 2020-03-24 13:05 common/lxd/database/local.db
-rw-r--r-- root/root 40960 2020-02-04 15:57 common/lxd/database/local.db.bak
drwx------ root/root 0 2018-09-18 11:21 common/lxd/security/
drwx------ root/root 0 2020-04-21 17:00 common/lxd/security/seccomp/
-rw------- root/root 204 2020-03-10 10:07 common/lxd/security/seccomp/jp-u1804
-rw------- root/root 204 2020-04-24 09:00 common/lxd/security/seccomp/jp-pss
-rw------- root/root 204 2020-04-24 09:00 common/lxd/security/seccomp/j2004
-rw------- root/root 204 2020-04-23 08:32 common/lxd/security/seccomp/gui1804
drwx------ root/root 0 2018-09-18 11:21 common/lxd/security/apparmor/
drwx------ root/root 0 2020-04-21 17:00 common/lxd/security/apparmor/profiles/
-rw------- root/root 22720 2020-04-21 16:32 common/lxd/security/apparmor/profiles/lxd-gui1804
-rw------- root/root 22714 2020-04-21 17:00 common/lxd/security/apparmor/profiles/lxd-j2004
-rw------- root/root 22741 2020-04-17 07:30 common/lxd/security/apparmor/profiles/lxd-jp-pss
-rw------- root/root 21781 2020-02-21 16:32 common/lxd/security/apparmor/profiles/lxd-jp-u1804
drwx------ root/root 0 2020-04-21 17:00 common/lxd/security/apparmor/cache/
-rw------- root/root 42249 2020-04-21 16:32 common/lxd/security/apparmor/cache/lxd-gui1804
-rw------- root/root 42033 2020-04-21 17:00 common/lxd/security/apparmor/cache/lxd-j2004
-rw------- root/root 42945 2020-04-17 07:30 common/lxd/security/apparmor/cache/lxd-jp-pss
-rw-r--r-- root/root 1531 2018-09-18 11:21 common/lxd/security/apparmor/cache/.features
-rw------- root/root 41465 2020-02-21 16:32 common/lxd/security/apparmor/cache/lxd-jp-u1804
drwx--x--x root/root 0 2018-09-18 09:07 common/lxd/storage-pools/
drwx--x--x root/root 0 2020-01-24 15:28 common/lxd/storage-pools/default/
drwx--x--x root/root 0 2020-01-24 15:28 common/lxd/storage-pools/default/virtual-machines-snapshots/
drwx--x--x root/root 0 2020-01-24 15:28 common/lxd/storage-pools/default/custom-snapshots/
drwx--x--x root/root 0 2020-01-24 15:28 common/lxd/storage-pools/default/virtual-machines/
drwx------ root/root 0 2019-05-08 16:27 common/lxd/storage-pools/default/containers-snapshots/
drwx------ root/root 0 2019-05-08 16:27 common/lxd/storage-pools/default/containers-snapshots/jp-u1804/
drwx------ root/root 0 2019-05-08 16:27 common/lxd/storage-pools/default/containers-snapshots/jp-u1804/snapsh-po_qhm/
drwx--x--x root/root 0 2018-09-18 09:07 common/lxd/storage-pools/default/custom/
drwx--x--x root/root 0 2020-04-21 17:00 common/lxd/storage-pools/default/containers/
drwx--x--x root/root 0 2019-05-08 11:42 common/lxd/storage-pools/default/containers/jp-u1804/
d--x------ root/root 0 2020-01-10 09:52 common/lxd/storage-pools/default/containers/jp-pss/
d--x------ root/root 0 2020-04-21 17:00 common/lxd/storage-pools/default/containers/j2004/
d--x------ root/root 0 2019-07-23 16:24 common/lxd/storage-pools/default/containers/gui1804/
drwx------ root/root 0 2020-04-24 15:01 common/lxd/storage-pools/default/images/
drwx--x--x root/root 0 2020-04-24 15:00 common/lxd/storage-pools/default/images/bba6e6c27482a82d47dc176fd29c964e8d93df0408f1845105953ba0bd22fcad/
drwx------ root/root 0 2019-05-08 11:36 common/lxd/storage-pools/default/images/f71e76edd33548e6c898fad9778997f84d494ad779761ce34826c41031c151fc/
drwx------ root/root 0 2018-09-18 07:37 common/lxd/backups/
-rw------- root/root 3243 2018-05-15 17:49 common/lxd/server.key
lrwxrwxrwx root/root 0 2018-08-20 08:05 common/lxd/shmounts -> /var/snap/lxd/common/shmounts/containers
drwx--x--x root/root 0 2020-04-21 17:00 common/lxd/containers/
lrwxrwxrwx root/root 0 2019-05-08 11:42 common/lxd/containers/assuring-oyster -> /var/snap/lxd/common/lxd/storage-pools/default/containers/assuring-oyster
lrwxrwxrwx root/root 0 2019-05-08 16:13 common/lxd/containers/jp-u1804 -> /var/snap/lxd/common/lxd/storage-pools/default/containers/jp-u1804
lrwxrwxrwx root/root 0 2020-01-10 09:52 common/lxd/containers/jp-pss -> /var/snap/lxd/common/lxd/storage-pools/default/containers/jp-pss
lrwxrwxrwx root/root 0 2020-04-21 17:00 common/lxd/containers/j2004 -> /var/snap/lxd/common/lxd/storage-pools/default/containers/j2004
lrwxrwxrwx root/root 0 2019-07-23 16:24 common/lxd/containers/gui1804 -> /var/snap/lxd/common/lxd/storage-pools/default/containers/gui1804
-rw-r--r-- root/root 0 2019-01-08 20:30 common/lxd/.shutdown
drwx------ root/root 0 2020-01-10 09:51 common/lxd/snapshots/
lrwxrwxrwx root/root 0 2019-05-08 16:27 common/lxd/snapshots/jp-u1804 -> /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/jp-u1804
drwx------ root/root 0 2020-04-24 15:01 common/lxd/images/
-rw-r--r-- root/root 102006784 2020-04-24 15:00 common/lxd/images/bba6e6c27482a82d47dc176fd29c964e8d93df0408f1845105953ba0bd22fcad.rootfs
-rw-r--r-- root/root 560 2020-04-24 15:00 common/lxd/images/bba6e6c27482a82d47dc176fd29c964e8d93df0408f1845105953ba0bd22fcad
-rw------- root/root 3407953470 2019-05-08 11:27 common/lxd/images/f71e76edd33548e6c898fad9778997f84d494ad779761ce34826c41031c151fc
drwx--x--x root/root 0 2018-09-18 09:07 common/lxd/networks/
drwx--x--x root/root 0 2020-02-04 08:27 common/lxd/networks/lxdbr1/
-rw-r--r-- root/root 1 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.raw
-rw-r--r-- root/root 47 2020-04-24 17:58 common/lxd/networks/lxdbr1/dnsmasq.leases
-rw-r--r-- root/root 694 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.pid
drwxr-xr-x root/root 0 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.hosts/
-rw-r--r-- root/root 44 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.hosts/jp-u1804
-rw-r--r-- root/root 33 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.hosts/jp-pss
-rw-r--r-- root/root 24 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.hosts/j2004
-rw-r--r-- root/root 26 2020-04-24 17:10 common/lxd/networks/lxdbr1/dnsmasq.hosts/gui1804
drwx--x--x root/root 0 2020-02-04 08:27 common/lxd/networks/lxdbr0/
-rw-r--r-- root/root 1 2020-04-24 17:10 common/lxd/networks/lxdbr0/dnsmasq.raw
-rw-r--r-- root/root 47 2018-09-18 08:55 common/lxd/networks/lxdbr0/dnsmasq.leases
-rw-r--r-- root/root 694 2020-04-24 17:10 common/lxd/networks/lxdbr0/dnsmasq.pid
drwxr-xr-x root/root 0 2018-09-18 08:55 common/lxd/networks/lxdbr0/dnsmasq.hosts/
-rw-r--r-- root/root 1895 2018-05-15 17:49 common/lxd/server.crt
drwxr-xr-x root/root 0 2018-05-15 17:49 common/lxc/
-rw-r--r-- root/root 0 2020-04-24 17:10 common/lxc/local.conf
-rw------- root/root 5 2020-04-24 17:10 common/lxcfs.pid
drwx--x--x root/root 0 2018-08-20 08:05 common/shmounts/
lrwxrwxrwx root/root 0 2020-04-24 17:10 common/mntns -> /proc/6746/root
drwxr-xr-x root/root 0 2018-05-15 17:49 common/var/
drwxr-xr-x root/root 0 2018-08-20 08:05 common/var/lib/
lrwxrwxrwx root/root 0 2018-08-20 08:05 common/var/lib/lxcfs -> /var/snap/lxd/common/shmounts/lxcfs
-rw-r--r-- root/root 225 2020-04-22 13:03 common/config
drwx------ root/root 0 2018-08-20 08:05 common/ns/
stgraber
(Stéphane Graber)
April 28, 2020, 2:46pm
34
Ok, so the backup doesn’t contain anything useful as far as containers.
This makes sense since your storage pool is stored on a dedicated partition but makes it even less clear where the data would have gone…
For the u1804 container, can you try:
lxc copy jp-u1804@snapsh-po_qhm blah
lxc start blah
See if that snapshot is useful somehow?
There is another problem…
root@jp-laptop:~# lxc copy jp-u1804/snapsh-po_qhm blah
root@jp-laptop:~# lxc start blah
root@jp-laptop:~# lxc list
| blah | RUNNING | 10.72.203.66 (eth0) | fd42:17ed:e97f:8bf9:216:3eff:fec9:d55 (eth0) | CONTAINER | 0 |
root@jp-laptop:~# lxc exec blah bash
bash: /root/.bashrc: Permission denied
root@blah:~#
I think I avoid recover these two containers, make export good ones, purge everyting including zfs device and starting lxd from beginning …
Mistake as usual - BACKUP BEFORE UPGRADE!
@stgraber Thank You for help and your dedicated time !
