Yes to us.
Can I add uk.images.linuxcontainers.org to the remote list and laucnh new CT from it ?
Yep, lxc remote add images-uk uk.images.linuxcontainers.org --type=simplestreams
should do it, then use images-uk:
instead of images:
I have exactly the same problem. I’m from Europe and I’m redirected to uk mirror. Using uk.images.linuxcontainers.org
directly helps.
What does https://www.maxmind.com/en/locate-my-ip-address show for your IP?
The servers just use a geoip database to redirect based on country I believe.
It looks like this page requires JavaScript to work so I can’t check it out (I’m on a remove server).
Here is output from curl
curl -v https://images.linuxcontainers.org
* Rebuilt URL to: https://images.linuxcontainers.org/
* Trying 2001:67c:1562::41...
* TCP_NODELAY set
* Connected to images.linuxcontainers.org (2001:67c:1562::41) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
It hangs here. It looks like TCP connection is established but there is no response to TLS client hello
. It worked a week ago.
curl -v https://uk.images.linuxcontainers.org
works normal.
