Thank you for the input! Had looked through the online documentation which though seems to feature only the syntax pertaining to the most recent version but no diversifaction for previous versions.
Unfortunately some distros are a bit slow(er) with adopting package updates from upstream, e.g. Debian-Stretch is providing lxc 2.0.7.2 in the stable channel. That makes it harder to keep up with changes in the documented syntax.
