A basic GPU question
Here is my gpu information and want to add that device but I havent done it.
GPU:NUMA node: 0
Driver: panthor (6.18.0-edge-rockchip64)
DRM:
Card: card0 (226:0)
Render: renderD128 (226:128)
I have tried, ```incus config device add llamacpp agpu gpu gputype=mdev=0```
Error: Failed to start device “agpu”: Failed to detect requested GPU device
Try incus info --show-log llamacpp for more info
But can start the device, anyone has idea how to add that kind of gpu to the vm?
Is that GPU its own PCI device?
If not, you won’t be able to pass it to a VM.
The output above suggests that this is an embedded GPU on an ARM board, so very unlikely to be connected internally over PCI.
Humm, thanks.
Regards.
