A fun project: microvms with Incus
I saw this blog post for microvms in Proxmox, and it got me thinking, “Couldn’t I do the same in Incus?” So I decided to mess around and see if I could end up with a profile I could make, to make use of qemu’s microvm feature in Incus. It turns out, it’s entirely possible to get it working, and it works better than I could have imagined.
What’s a microvm?
Here is QEMU’s own description:
microvm is a machine type inspired by Firecracker and constructed after its machine model. It’s a minimalist machine type without PCI nor ACPI support, designed for short-lived guests. microvm also establishes a baseline for benchmarking and optimizing both QEMU and guest operating systems, since it is optimized for both boot time and footprint.
A regular Incus VM is a full emulated machine: a q35 chipset, a PCIe topology, ACPI, and UEFI firmware (OVMF) that runs a bootloader off the guest disk, which then loads the guest’s own kernel and initramfs. It behaves like a physical PC. A microvm throws nearly all of that away. There is no firmware in the boot path at all, so QEMU is handed a kernel directly and jumps straight into it. The result sits much closer to a container in overhead, while still being a real, isolated VM with its own kernel.
One thing surprised me, and it is worth clearing up because QEMU’s wording is a little misleading. The definition says “without PCI nor ACPI,” but that describes the bare default (pure virtio-mmio, the Firecracker-like model). The microvm machine type also has opt-in pcie=on and acpi=on switches. I turn both on. That is deliberate: PCI is what lets Incus hot-plug a normal NIC into the guest, and it is also what made the SR-IOV experiment below work. So you get to choose where on the minimalism spectrum you want to sit.
The catch: you supply the kernel
Because there is no firmware and no bootloader, the guest’s own kernel never runs. You hand QEMU a kernel with -kernel, and that kernel has to be able to mount any guest’s root filesystem and bring up the Incus agent entirely on its own.
So I built a small, monolithic kernel (CONFIG_MODULES=n, everything compiled in, no /lib/modules needed in the guest at all) tuned for my CPU. The rule is that everything the guest could need has to be built in (=y), because there is no initramfs to load modules from:
  • virtio blk / net / scsi / console / balloon / rng, plus VIRTIO_PCI
  • 9p + virtio-9p + vsock + virtio-vsock (this is what the Incus agent rides on; miss it and the VM boots fine but the agent never appears)
  • ext4, vfat, overlayfs, virtiofs
  • the netfilter stack, TCP BBR, and so on
  • BPF_SYSCALL (modern systemd wants it)
  • and, just to see if it would work, the iavf driver for Intel SR-IOV virtual functions
Stripped down from a distro defconfig it lands around 12 MiB and boots a guest to userspace in roughly a quarter of a second.
The profile
This is where Incus really shines. raw.qemu.scriptlet lets you rewrite the QEMU configuration in Starlark before the VM launches. I use it to switch the machine type to microvm and drop the firmware bits Incus adds for q35:
def qemu_hook(instance, stage):
    if stage == "config":
        out = []
        for s in get_qemu_conf():
            n, e = s["name"], s["entries"]
            if n == "machine":
                e["type"] = "microvm"
                e["acpi"] = "on"; e["pcie"] = "on"; e["rtc"] = "on"
            elif n == "drive" and e.get("if") == "pflash":
                continue          # no OVMF
            elif n == "global" and e.get("driver") == "ICH9-LPC":
                continue          # q35 southbridge, gone
            out.append(s)
        set_qemu_conf(out)
The scriptlet can rewrite the machine config, but it cannot add -kernel. That goes in plain raw.qemu. Here is the whole profile:
  security.secureboot: "false"
  limits.cpu: sockets=1,cores=4,threads=1
  limits.memory: 2GiB
  raw.qemu: -kernel /path/to/microvm-kernel -append "root=/dev/vda2 rootwait rw console=ttyS0"
  raw.qemu.scriptlet: |-
    ... the Starlark above ...
    nictype: bridged
    parent: br0
    pool: default
    io.bus: virtio-blk   # makes the disk show up as /dev/vda
And then it is just:
incus launch images:debian/13 test --vm -p microvm
The gotchas
None of these were obvious, so I am writing them down for anyone who wants to try this:
  1. CPU hotplug. Incus always asks QEMU about hot-pluggable CPUs, and microvm does not support that, so the VM dies on start. The fix is to set limits.cpu as a topology (sockets=1,cores=4,threads=1) rather than a plain number. A fixed topology disables hotplug and the error goes away.
  2. Secure Boot. Incus refuses to create the VM (“incompatible with secureboot”) before the scriptlet ever runs. Since there is no OVMF here anyway, security.secureboot=false is the correct setting, not a compromise.
  3. ro vs rw, the sneaky one. With root=... ro in the append, Alpine and Debian were fine, but Arch came up with no networking and no DNS. The cause: Arch’s cloud image ships with no /etc/machine-id and relies on systemd generating one on first boot. At that moment /etc is still read-only, so systemd cannot write it, and with no machine-id it cannot build a DHCP DUID, so systemd-networkd fails the whole link. A normal VM dodges this because its initramfs has root writable in time. Booting rw fixes it cleanly, and Arch then generates its own machine-id on first boot like it should.
  4. BPF_SYSCALL. Without it, systemd logs Unable to load sysctl monitor BPF program: Function not implemented. Not fatal, but build it in to keep modern systemd happy.
Does one profile really boot anything?
That was the real question: one profile, or one profile per image? It turns out to be genuinely one profile. With the same microvm profile I launched Alpine, Arch, and Debian/trixie, all unmodified, and all three boot, get an IP, and resolve DNS with no per-image tweaks. Even better, the incus agent works just like a normal VM. The only assumptions are an ext4 root on partition 2 (every Incus image I tried uses that) and the matching filesystem built into the kernel. Because you bypass the image’s own initramfs, anything that depends on it (LUKS, LVM-on-root) will not work, but ordinary cloud images just go.
The numbers
Same Alpine image, same 1 GiB of RAM, idle just after boot:
microvm normal q35 + OVMF
host RAM (qemu Pss) ~196 MiB ~379 MiB
Boot time, measured as incus start to the agent answering, warm restarts, same Alpine image:
microvm (our kernel, direct boot) q35 (OVMF + image kernel + initramfs)
start to agent ~5 s ~8 s
The memory saving is the headline here: roughly half the host RAM for the same guest. With the high cost of RAM lately, this matters, and it matters more the more guests you pack onto a box.
The boot speedup is real too, but more modest, around three seconds. It is worth being precise about where it comes from, because it is not just skipping the bootloader. A normal VM spends time in the OVMF firmware, then the bootloader, then the kernel’s own initramfs, all before userspace even starts. The microvm skips that entire chain and runs a smaller kernel that initializes in about a quarter of a second. Once the distro’s userspace and the Incus agent come up, the two paths are identical, which is why the gap is a few seconds rather than tenfold. For a single VM that is minor; for a fleet of short-lived guests it adds up, and the RAM difference adds up a good deal faster.
Bonus: SR-IOV works too
Since I had built the iavf driver into the kernel, I tried attaching an SR-IOV virtual function from a physical NIC to one of these microvms, with a VLAN set on the VF. It just worked. The host hands the VF through, the guest drives the passed-through NIC natively with iavf, and the link comes up tagged on the correct VLAN. So these are not just toys; they can have real, line-rate hardware networking.
This is also why I keep PCI enabled. I did consider the pure virtio-mmio (no-PCI) variant, which is the most minimal microvm of all. But when I actually measured it, the difference was tiny: roughly 2 MiB less host RAM and only a couple dozen milliseconds faster to boot. That is not worth giving up PCI for, because PCI is what makes device passthrough and NIC hot-plug possible in the first place. So I leave pcie=on and get the passthrough abilities essentially for free.
What I have not tried (and probably will not work)
To be clear about scope: I only ran this on a single host in a homelab. I have not touched any of the cluster-oriented features, and I would expect most of them not to work as-is. Live migration, cluster scheduling and evacuation, and anything that assumes a standard machine type or a stable firmware and CPU model across hosts all seem unlikely to behave. Snapshots and config copies of the instance should be fine, but I have not stress-tested those either. Treat this as “fun and genuinely useful on one box,” not “production cluster-ready.”
I would love to see this officially supported
What strikes me most is how little it took: a small kernel and a short scriptlet, and you end up with what feels like a real middle ground between a container and a VM. A true, isolated guest with its own kernel, but at close-to-container overhead and boot time. I would love to see microvm become a first-class, supported option in Incus, because from the outside it does not look like it would be hard to add.
And here is the best part: none of this requires patching or modifying Incus at all. Everything above is just configuration and a scriptlet on a stock Incus. So even though it is not official, it is already entirely available to anyone who wants to do it today.
What I plan to do next
I’m currently working on a way to convert OCI images and container rootfs to microvms that work in Incus. If I’m able to accomplish all that, I’m considering proposing it as a new feature for future versions of Incus, if that’s a direction the project is interested in going.
Happy to share more info if anyone has any questions or needs help.
This is the description of the microvm machine type that QEMU supports; the concept of micro VMs is a bit broader.
This is the Direct Kernel Boot feature of QEMU, which is orthogonal to micro VMs really; you definitely can boot directly to your kernel on a q35 machine, I’m doing it all the time.
So you are essentially rebuilding a kind of q35 machine on top of the microvm one, which probably ends up even heavier than q35 as you now end up with useless additional virtio-mmio devices that Incus doesn’t use.
That’s already supported by Incus thanks to raw.qemu overrides.
Don’t you get comparable results with a q35 machine with Direct Kernel Boot?
And you’d keep hotswapping, which is the whole point of Incus using q35.
So, I’m not sure what you are exactly trying to achieve, but my guess is that you really are only interested in Direct Kernel Boot. I may be wrong though.
For the record, we’re working on improving Direct Kernel Boot support in Incus and on OCI VMs, which should appear later this year.
Here I was thinking I had made a breakthrough. It’s good to get a word from someone who knows more than I do. :+1:
Using the exact same setup with q35, the RAM usage is 3MB higher, start to userspace is 0.7s with microvm vs 1.5s with q35. PCI vs no PCI with microvm difference is margin of error (I got 0.9s with non-PCI).
In other words, indeed, direct kernel boot matters, and machine type does not. I had assumed that using microvm machine type would be advantageous, but the advantage is negligible.
It’s nice that the direct boot is already in progress. It will be a feature to look forward to.
To be fair with you, QEMU introduced plenty of confusion with that microvm machine type, and people use the term to talk about many different things at once, some use the term for minimalist VMs like Firecracker does, some use it for wrapped containers like Kata containers (which can use Firecracker), and I’m skipping a few. What we really want is something that boots faster and with a smaller footprint, which, with equivalent kernel and resources, almost always amounts to removing the firmware and bootloader altogether.
Here is an example project for microVMs a la Firecracker, GitHub - angelorc/vmsan: Firecracker made simple. Spin up secure microVMs in milliseconds, from install to interactive shell in one command. · GitHub I posted about it. The project apparently did not get much traction and has not been updated since.
There was a recent thread about adding support for Firecracker into Incus. This should give you an idea on what is minimally needed for a proof of concept.
There is a case to be made for microvm infrastructure as an alternative to application containers, system containers and heavyweight virtual machines.
I’ve read that QEMU microvm isn’t in the same class of footprint and security isolation as VMMs like Cloud Hypervisor and Firecracker.
Cloud Hypervisor supports PCIe passthrough for LLMs. Firecracker doesn’t but there was discussion about somehow achieving something similar with a more secure abstraction (not via the standard PCIe passthrough mechanisms).
Could Incus support the addition of a third-party microvm hypervisor, such as Cloud Hypervisor or Firecracker, running alongside its established QEMU hypervisor? Is that even necessary if QEMU microvm is as secure as Cloud Hypervisor? Especially if QEMU microvm supports Native Context.
