Greetings team,
So I have an instance in my ovn network and I would like to be able to reach it from my lan network. I was reading and thinking about the best way to do this and I decided to try it via load-balancing. I am unsure if what I am doing is correct, but I created a load-balancer and add one of my linstor test nodes to the load-balancer and I would like to be able to reach the gui (which is installed and on port 8080).
I can’t reach it via the network volatile ipv4 address that its on, did I miss something?
Here is my ovn network
root@supermicro:/home/mihai# incus network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| linstor-testing | ovn | YES | 10.18.191.1/24 | fd42:4360:9cd5:ae3f::1/64 | linstor testing | 0 | CREATED |
root@supermicro:/home/mihai# incus network show linstor-testing
bridge.mtu: "1500"
ipv4.address: 10.18.191.1/24
ipv4.nat: "true"
ipv6.address: fd42:4360:9cd5:ae3f::1/64
ipv6.nat: "true"
network: UPLINK-admin_labs
volatile.network.ipv4.address: 10.200.10.2
description: 'linstor testing '
type: ovn
used_by: []
managed: true
status: Created
locations:
- r620
- r720-3
- supermicro
- r720-2
project: admin-labs
Here is my UPLINK
root@supermicro:/home/mihai# incus project switch default
root@supermicro:/home/mihai# incus network show UPLINK-admin_labs
dns.nameservers: 1.1.1.1
ipv4.gateway: 10.200.10.1/24
ipv4.ovn.ranges: 10.200.10.2-10.200.10.254
volatile.last_state.created: "false"
type: physical
- /1.0/networks/linstor-testing?project=admin-labs
managed: true
status: Created
locations:
- supermicro
- r720-2
- r620
- r720-3
project: default
Here is my load-balancer
root@supermicro:/home/mihai# incus network load-balancer show linstor-testing 10.200.10.2
config: {}
backends:
- name: linstor-gui
target_port: "8080"
target_address: 10.18.191.2
ports:
- description: ""
protocol: tcp
listen_port: "8080"
target_backend:
- linstor-gui
listen_address: 10.200.10.2
root@supermicro:/home/mihai# incus network load-balancer list linstor-testing
| LISTEN ADDRESS | DESCRIPTION | PORTS | LOCATION |
| 10.200.10.2 | | 1 | |
And my instance
root@supermicro:/home/mihai# incus ls
| linstor1 | RUNNING | 10.18.191.2 (enp5s0) | fd42:4360:9cd5:ae3f:216:3eff:fe1f:30b0 (enp5s0) | VIRTUAL-MACHINE | 0 | supermicro |
