Hi.
I have configured and used macvlan or ipvlan to access the contaiener or vm from the outside.
If I use a fan network as an overlay network in lxd cluster, how can I access the container from the external network?
and…
In general, the IP address of the underaly network uses the same IP address space. Why is the IP address of the underlay network different for each host in lxd? (Is it because of the expansion of ip address, a unique feature of fan network?)
Is there a way to expose internal services to the outside like openshift?
Thank you
