Following some other posts, here the tcpdump for dig +tcp acmedns-ind01 @10.89.1.1
root@proxy01:~# tcpdump -nn -i eth0 port 53
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
16:40:31.175647 IP 240.102.0.47.50741 > 10.89.1.1.53: Flags [S], seq 4170258847, win 64860, options [mss 1410,sackOK,TS val 3010699785 ecr 0,nop,wscale 7], length 0
16:40:31.175745 IP 10.89.1.1.53 > 240.102.0.47.50741: Flags [S.], seq 266882846, ack 4170258848, win 64308, options [mss 1410,sackOK,TS val 1525447471 ecr 3010699785,nop,wscale 7], length 0
16:40:31.175772 IP 240.102.0.47.50741 > 10.89.1.1.53: Flags [.], ack 1, win 507, options [nop,nop,TS val 3010699785 ecr 1525447471], length 0
16:40:31.176054 IP 240.102.0.47.50741 > 10.89.1.1.53: Flags [P.], seq 1:57, ack 1, win 507, options [nop,nop,TS val 3010699785 ecr 1525447471], length 56 48641+ [1au] A? acmedns-ind01. (54)
16:40:31.176118 IP 10.89.1.1.53 > 240.102.0.47.50741: Flags [.], ack 57, win 502, options [nop,nop,TS val 1525447471 ecr 3010699785], length 0
16:40:31.176316 IP 10.89.1.1.53 > 240.102.0.47.50741: Flags [F.], seq 1, ack 57, win 502, options [nop,nop,TS val 1525447471 ecr 3010699785], length 0
16:40:31.176397 IP 10.89.1.1.53 > 240.102.0.47.50741: Flags [R.], seq 2, ack 57, win 502, options [nop,nop,TS val 1525447472 ecr 3010699785], length 0
16:40:31.176797 IP 240.102.0.47.51865 > 10.89.1.1.53: Flags [S], seq 3908763312, win 64860, options [mss 1410,sackOK,TS val 3010699786 ecr 0,nop,wscale 7], length 0
16:40:31.176891 IP 10.89.1.1.53 > 240.102.0.47.51865: Flags [S.], seq 13154576, ack 3908763313, win 64308, options [mss 1410,sackOK,TS val 1525447472 ecr 3010699786,nop,wscale 7], length 0
16:40:31.176926 IP 240.102.0.47.51865 > 10.89.1.1.53: Flags [.], ack 1, win 507, options [nop,nop,TS val 3010699786 ecr 1525447472], length 0
16:40:31.177250 IP 240.102.0.47.51865 > 10.89.1.1.53: Flags [P.], seq 1:57, ack 1, win 507, options [nop,nop,TS val 3010699786 ecr 1525447472], length 56 24475+ [1au] A? acmedns-ind01. (54)
16:40:31.177298 IP 10.89.1.1.53 > 240.102.0.47.51865: Flags [.], ack 57, win 502, options [nop,nop,TS val 1525447472 ecr 3010699786], length 0
16:40:31.177411 IP 10.89.1.1.53 > 240.102.0.47.51865: Flags [F.], seq 1, ack 57, win 502, options [nop,nop,TS val 1525447473 ecr 3010699786], length 0
16:40:31.177476 IP 10.89.1.1.53 > 240.102.0.47.51865: Flags [R.], seq 2, ack 57, win 502, options [nop,nop,TS val 1525447473 ecr 3010699786], length 0
For the udp request dig acmedns-ind01 @10.89.1.1
16:41:54.185401 IP 240.102.0.47.52727 > 10.89.1.1.53: 53769+ [1au] A? acmedns-ind01. (54)
16:41:59.186419 IP 240.102.0.47.52727 > 10.89.1.1.53: 53769+ [1au] A? acmedns-ind01. (54)
16:42:04.190404 IP 240.102.0.47.52727 > 10.89.1.1.53: 53769+ [1au] A? acmedns-ind01. (54)
17 packets captured
17 packets received by filter
0 packets dropped by kernel
Unfortunately I’m not familiar with using tcpdump, so I’m still clueless.
root@proxy01:~# sudo iptables-save; sudo ip6tables-save; sudo nft list ruleset
sudo: iptables-save: command not found
sudo: ip6tables-save: command not found
