I’m having issues with the unix.socket of my lxd install. When I run lxc list I get:
seuberte@rainier:~$ lxc list
Error: Get "http://unix.socket/1.0": dial unix /var/snap/lxd/common/lxd/unix.socket: connect: permission denied
I think it might be related to my attempt to back up my LXD to iDrive, I set the ACL of /var/ so that the idrive group on my machine can read the directory.
After restarting the lxd through snap, this is what the file permissions look like:
seuberte@rainier:~$ sudo snap stop lxd
Stopped.
seuberte@rainier:~$ sudo snap start lxd
Started.
seuberte@rainier:~$ sudo ls /var/snap/lxd/common/lxd -lah
total 76K
drwx--x--x+ 17 root root 4.0K Apr 10 12:47 .
drwxr-xr-x+ 9 root root 4.0K Apr 10 12:47 ..
drwx------+ 4 root root 4.0K Aug 7 2021 backups
drwx------+ 4 root root 4.0K Sep 16 2021 cache
drwx--x--x+ 2 root root 4.0K Feb 2 02:58 containers
drwx------+ 4 root root 4.0K Apr 10 12:47 database
drwx--x--x+ 3 root root 4.0K Apr 10 12:47 devices
drwxr-xr-x+ 2 root root 4.0K Aug 7 2021 devlxd
drwx------+ 2 root root 4.0K Aug 7 2021 disks
drwx------+ 2 root root 4.0K Sep 30 2021 images
drwx------+ 3 root root 4.0K Apr 10 12:47 logs
drwx--x--x+ 3 root root 4.0K Sep 23 2021 networks
srwx------+ 1 root root 0 Apr 10 12:47 seccomp.socket
drwx------+ 4 root root 4.0K Aug 7 2021 security
-rw-r--r--+ 1 root root 765 Aug 7 2021 server.crt
-rw-------+ 1 root root 288 Aug 7 2021 server.key
lrwxrwxrwx 1 root root 39 Apr 10 12:12 shmounts -> /var/snap/lxd/common/shmounts/instances
drwx------+ 2 root root 4.0K Aug 7 2021 snapshots
drwx--x--x+ 3 root root 4.0K Aug 8 2021 storage-pools
srw-r-----+ 1 root lxd 0 Apr 10 12:47 unix.socket
drwx--x--x+ 2 root root 4.0K Aug 15 2021 virtual-machines
drwx------+ 2 root root 4.0K Aug 7 2021 virtual-machines-snapshots
seuberte@rainier:~$ sudo getfacl /var/snap/lxd/common/lxd/unix.socket
getfacl: Removing leading '/' from absolute path names
# file: var/snap/lxd/common/lxd/unix.socket
# owner: root
# group: lxd
user::rw-
group::r-x #effective:r--
group:idrive:r-x #effective:r--
mask::r--
other::---
I’ve tried setting the mask on the ACL to r-x, but after restarting lxd, it reverts to this.
Am I missing something/do something wrong with ACLs? Has anybody got any advice?
Thanks in advanced!
