Hi.
I tried to add disk to vm like adding disk to container, but it says that there is no disk type (unix-block).
How do I add a disk to lxd vm?
Thank you
Hi.
Thank you
lxc config device add VM-NAME my-disk disk source=/path/to/disk/or/partition
Could u give a live command example?
What do you mean? The above is the command to add a block disk device to a VM.
What error/issue are you experiencing?
