I am able to create a working network in an lxd cluster;
My lxd version is 3.0.3;
the servers are in the same network and they are configured to work in the same lxd cluster;
I configured testbr0 to use vxlan tunnelling.(Example 1)
The next step is to create a link between 2 different running containers in the cluster;
for example, in this scenario, I want to add 4 links (Example 2)
is it possible to create a bridge (ex. Br-c1-c2) and 2 new interfaces in C1 and C2, connect the 2 new interfaces using Br-c1-c2 and assign ip address while the containers are running?
I want to do the same thing also when the containers are in the same Host (ex. Br-c2-c3)
What are the best practices to do that?
The last question is:
Why when I want to create a new network we first need to create to each physical node and then actually create it without the --target?
Looking at your example 2 drawing: why not create GRE tunnel interfaces between the containers? They all look point to point interfaces to me. Or you had something else in your mind?
Looking at the different techniques, GRE will probably win. Both do encapsulation, but GRE is protocol based (no ports used) and VXLAN is Layer 4 (uses UDP port), so I expect the overhead of GRE to be less than VXLAN and so faster
Besides that…GRE is easier to implement i.m.o.
