I’m trying to add node to the cluster, but get error:
Would you like to use LXD clustering? (yes/no) [default=no]: yes
What name should be used to identify this node in the cluster? [default=t01]:
What IP address or DNS name should be used to reach this node? [default=192.168.88.252]:
Are you joining an existing cluster? (yes/no) [default=no]: yes
IP address or FQDN of an existing cluster node: 192.168.88.246
Cluster fingerprint: ################################################################
You can validate this fingerprint by running "lxc info" locally on an existing node.
Is this the correct fingerprint? (yes/no) [default=no]: yes
Cluster trust password:
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose "source" property for storage pool "local": zfs
Choose "zfs.pool_name" property for storage pool "local": t01
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]: yes
config: {}
networks: []
storage_pools: []
profiles: []
cluster:
server_name: t01
enabled: true
member_config:
- entity: storage-pool
key: source
value: zfs
description: '"source" property for storage pool "local"'
key: zfs.pool_name
value: t01/lxd
description: '"zfs.pool_name" property for storage pool "local"'
cluster_address: 192.168.88.246:8443
cluster_certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
server_address: 192.168.88.252:8443
cluster_password: ########################
Error: Failed to join cluster: Failed to initialize member: Failed to initialize storage pools and networks: Failed to create storage pool 'local': The source must match zfs.pool_name if specified
How can I add a node to a cluster and use the pool I want for this node?
