Adding A Proxy Device
I would like to expose Juju GUI running in a container to the local network. To do that I need to proxy traffic coming to the host interface connected to the local network to the container interface on which Juju GUI is listening.
I added a proxy device without a problem but nobody is listening. :confused:
snap install
tracking:        edge
installed:       git-8c3633c (5451) 44MB -
Create a container lxc launch ubuntu:xenial xen1
Add proxy device lxc config device add xen1 proxy0 proxy listen=tcp:192.168.50.196:80 connect=tcp:10.0.10.88:80 bind=host
Check if device is there
$ lxc config device show xen1
proxy0:
  bind: host
  connect: tcp:10.0.10.147:443
  listen: tcp:192.168.50.196:443
  type: proxy
Connection refused
$ wget https://192.168.50.196/
--2018-01-20 01:06:38--  https://192.168.50.196/
Connecting to 192.168.50.196... failed: Connection refused.
Nobody is listenining on 443
$ sudo netstat -tulp | grep 443
tcp6       0      0 [::]:8443               [::]:*                  LISTEN      24878/lxd
I can’t find any meaningful information in logs.
From log:
tail: /var/snap/lxd/common/lxd/logs/juju-1caef8-1/proxy.proxy0.log: file truncated
Listening on tcp:192.168.50.196:443 in 24878, forwarding to tcp:10.0.10.147:443 from 12226
Re-executing proxy process
lxd: error while loading shared libraries: liblxc.so.1: cannot open shared object file: No such file or directory
Bug report: https://github.com/lxc/lxd/issues/4186
This might be the issue.
I tried as well the same, and got the exact error.
i dont prefer proxy.
You can merely not not create a proxy device and that’s it.
You can continue using iptables as always.
fixed in f30b697
