I would like to add automatically specific VLAN tags on some LXD containers which use an openvswitch bridge. The bridge is not managed by LXD, but for the time being it is not a heavy constraint. Is such thing possible?
root@oowul:/var/lib/lxc/ora73c10# cat /etc/network/if-up.d/openvswitch/ora73c10-pub-ifup-sw1
!/bin/bash
ovsBr=‘sw1’
ovs-vsctl add-port ${ovsBr} $5
ovs-vsctl set port $5 tag=10
root@oowul:/var/lib/lxc/ora73c10# cat /etc/network/if-down.d/openvswitch/ora73c10-pub-ifdown-sw1
!/bin/bash
ovsBr=‘sw1’
sudo ovs-vsctl del-port ${ovsBr} $5
function CheckPortExists
sudo ovs-vsctl show | grep “$5” | grep Port | sed ‘s/^[ \t]//;s/[ \t]$//’ | cut -f2 -d’ ’ | sed ‘s/"//g’
PortExists=$(CheckPortExists)
if [ “$PortExists” = “$5” ]
then
fi
sudo ip link del $5
These commands will put the vlan tag on the openvswitch port at runtime when the container comes up and will optionally with the user of lxc.network.veth.pair give the veth pair a meaningful name other than the machine generated vethXyZwuV cyborg-type random name.
Note, as I recall this may not work on LXD and I had logged some tickets and notes that LXD does not seem to have a streamlined way to do VLAN tagging (it must be added after the interface is up, by some semi-manual or scripted add-on outside of LXD config I think).
