Hello!
I’ve been using LXD for about 2 years now with ZFS as a storage backend. My Storage pools are LVM-backed block devices. Unfortunately I didn’t enable ZFS compression back then. Yesterday I figured out that it might be a good idea to enable LZ4 compression, since it is capable of saving considerable amounts of storage space.
I enabled compression on both of my ZFS storage pools globally, but as I understood, compression is only applied to new / changed data - not data already existing. To achieve some compression now, I’d have to
re-write every file in each container or
copy the ZFS filesystem of a container, then delete the old one, and rename the new one to the name of the old file system. That way, all the data would have gone through a copy / write process, which uses compression.
(Also see: https://github.com/openzfs/zfs/issues/3013)
So I’d do the following (assuming I have a container mastodon on storage pool default:
Create a snapshot of my LXD container:
lxc snapshot mastodon without-compression
Then copy the snapshot over to a new file system, named similarly:
zfs send default/containers/mastodon@without-compression | zfs receive -F default/containers/mastodon_compressed
Now it’s time to shut down the mastodon container
lxc stop mastodon
… also remove all snapshots, because otherwise LXD will (by its SQL database) expect some snapshots to be existent on the mastodon_compressed file system, which of course will not exist after moving the mastodon_compressed file system in place:
lxc delete mastodon/snap1
lxc delete mastodon/snap2
lcx delete [..]
Delete the original, uncompressed file system:
zfs destroy default/containers/mastodon
Then move the new ZFS file system in place by renaming it from mastodon_compressed to its original name:
zfs rename default/containers/mastodon_compressed default/containers/mastodon
Now my question: Is this a valid approach to achieve compression of old data? Will my manual process interfere with LXD / LXD’s SQL database in any way? Are there more reliable ways to do it?
Thanks for your feedback. Would really appreciate it
Just noticed that compression seems to have been active on another storage pool for a while. But the storage pool that I have created later on (I guess manually by zfs commands) didn’t have it enabled. Seems like LXD is already enabling compression? Anyway, I still need to get it working on my other storage pool (with compression enabled yesterday), too
