Thanks @stgraber
I am unable to run another dnsmasq
process on host A
as the port 53
is already in use. Example:
$ dnsmasq --listen-address=192.168.0.10
dnsmasq: failed to create listening socket for port 53: Address already in use
And so, I tried to leverage resolved
to achieve my goal but was not successful. Example of my approach:
Since,
$ # Host A
$ cat /etc/systemd/resolved.conf.d/lxd.conf
[Resolve]
DNS=10.0.0.1
Domains=lxd
$ # Host A
$ curl svc_2.lxd
hello
Then on host B
I configured resolved
as well given host A
is reachable from B
as they are on the same LAN. So the configuration in this example:
$ # Host B
[Resolve]
DNS=192.168.0.10 # IP Address of host A
Domains=lxd
From host B
if i try to resolve svc_2.lxd
, I can see that it is going towards the configured IP address. Example:
12:57:36.657138 IP (tos 0x0, ttl 64, id 21227, offset 0, flags [DF], proto UDP (17), length 56)
gl-pc.41778 > 192.168.0.10.domain: 44594+ A? svc_2.lxd. (28)
And on host A
i can see incoming request from host B
. But unfortunately I do not have an resolver bound to 192.168.0.10
and the resolve request dies. I was hoping whether the dnsmasq
used by LXD could be adjusted accordingly. For instance, I was thinking whether I could append the IP address of host A
to --listen-address
flag of dnsmasq
and thus there would be a correct DNS server to respond to the query? If this could be a way to try, would you have an idea how i could add this configuration? For instance now i can see that the process is launched to listen only on the gateway of the bridge:
2057 dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=lxdbr0 --dhcp-rapid-commit --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=10.0.0.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts --dhcp-range 10.0.0.2,10.0.0.254,1h -s lxd --interface-name _gateway.lxd,lxdbr0 -S /lxd/ --conf-file=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw -u lxd -g lxd
