A few days ago I updated some Ubuntu 16.04 (with ZFS) boxes to lxd 3.0.1 from backports. The upgrade seemed to go OK: I saw it made a bunch of changes and got rid of my old /etc/default/lxd-bridge. Existing containers are still running. But now I find that I can’t create new containers:
root@nuc1:~# lxc launch ubuntu:16.04 snf-image
Creating snf-image
Error: Failed container creation: No root device could be found.
I’ve tried looking around, and don’t see anything obviously wrong:
root@nuc1:~# lxc image list
| ALIAS | FINGERPRINT | PUBLIC | DESCRIPTION | ARCH | SIZE | UPLOAD DATE |
| | f2228450779f | no | ubuntu 16.04 LTS amd64 (release) (20180703) | x86_64 | 157.56MB | Jul 6, 2018 at 1:07pm (UTC) |
root@nuc1:~# lxc storage list
| default | | zfs | zfs/lxd | 9 |
root@nuc1:~# lxc storage show default
source: zfs/lxd
zfs.pool_name: zfs/lxd
driver: zfs
- /1.0/containers/xxxx << snipped >>
status: Created
locations:
- none
root@nuc1:~# zfs list zfs/liblxd
zfs/liblxd 159M 39.2G 159M /var/lib/lxd
root@nuc1:~# zfs list -r zfs/lxd
zfs/lxd 16.5G 39.2G 96K none
zfs/lxd/containers 15.8G 39.2G 96K none
zfs/lxd/containers/builder 15.3M
... goes on to list other containers, then images
I also saw that newer lxd/lxd-client packages have been released since then, so I’ve just upgraded to those too, but with the same result. “systemctl restart lxd” didn’t make a difference either.
Looking in /var/log/lxd/lxd.log:
lvl=warn msg="Failed to update instance types: Get https://images.linuxcontainers.org/meta/instance-types/.yaml: lookup images.linuxcontainers.org on 10.12.255.1:53: read udp 10.12.255.11:43020->10.12.255.1:53: i/o timeout" t=2018-07-06T14:25:56+0100
ephemeral=false lvl=info msg="Creating container" name=snf-image t=2018-07-06T14:25:58+0100
created=2018-07-06T14:25:58+0100 ephemeral=false lvl=info msg="Deleting container" name=snf-image t=2018-07-06T14:25:58+0100 used=1970-01-01T01:00:00+0100
created=2018-07-06T14:25:58+0100 ephemeral=false lvl=info msg="Deleted container" name=snf-image t=2018-07-06T14:25:58+0100 used=1970-01-01T01:00:00+0100
ephemeral=false lvl=eror msg="Failed creating container" name=snf-image t=2018-07-06T14:25:58+0100
I think the error about failing to resolve against 10.12.255.1 (which happens when I do systemctl restart lxd) is a different problem to investigate separately: I can definitely resolve using dig @10.12.255.1 images.linuxcontainers.org. Furthermore, if I run tcpdump while restarting lxd, I can see the queries being answered.
14:29:27.844268 IP (tos 0x0, ttl 64, id 3133, offset 0, flags [DF], proto UDP (17), length 72)
10.12.255.11.57492 > 10.12.255.1.53: 39723+ AAAA? images.linuxcontainers.org. (44)
14:29:27.844812 IP (tos 0x0, ttl 64, id 3134, offset 0, flags [DF], proto UDP (17), length 72)
10.12.255.11.55622 > 10.12.255.1.53: 1940+ A? images.linuxcontainers.org. (44)
14:29:27.846230 IP (tos 0x0, ttl 64, id 24796, offset 0, flags [none], proto UDP (17), length 603)
10.12.255.1.53 > 10.12.255.11.57492: 39723 3/13/15 images.linuxcontainers.org. CNAME canonical.images.linuxcontainers.org., canonical.images.linuxcontainers.org. AAAA 2001:67c:1562::41, canonical.images.linuxcontainers.org. AAAA 2001:67c:1560:8001::21 (575)
14:29:27.847933 IP (tos 0x0, ttl 64, id 24797, offset 0, flags [none], proto UDP (17), length 547)
10.12.255.1.53 > 10.12.255.11.55622: 1940 3/13/13 images.linuxcontainers.org. CNAME canonical.images.linuxcontainers.org., canonical.images.linuxcontainers.org. A 91.189.91.21, canonical.images.linuxcontainers.org. A 91.189.88.37 (519)
But the primary problem is not being able to create containers, with “No root device could be found.”
Any suggestions for where else I can look?
Thanks … Brian.
apt history from initial upgrade:
Start-Date: 2018-07-01 22:20:03
Commandline: apt-get install -t xenial-backports lxd lxd-client python-pylxd
Install: xdelta3:amd64 (3.0.8-dfsg-1ubuntu2, automatic), liblxc-common:amd64 (3.0.1-0ubuntu1~16.04.1, automatic)
Upgrade: lxd:amd64 (2.0.11-0ubuntu1~16.04.4, 3.0.1-0ubuntu1~16.04.1), liblxc1:amd64 (2.0.8-0ubuntu1~16.04.2, 3.0.1-0ubuntu1~16.04.1), lxd-client:amd64 (2.0.11-0ubuntu1~16.04.4, 3.0.1-0ubuntu1~16.04.1), lxcfs:amd64 (2.0.8-0ubuntu1~16.04.2, 3.0.1-0ubuntu2~16.04.1)
Remove: lxc-common:amd64 (2.0.8-0ubuntu1~16.04.2)
End-Date: 2018-07-01 22:21:50
And subsequent upgrade:
Start-Date: 2018-07-06 14:15:36
Commandline: apt-get dist-upgrade
Upgrade: ... lxd:amd64 (3.0.1-0ubuntu1~16.04.1, 3.0.1-0ubuntu1~16.04.2), ... lxd-client:amd64 (3.0.1-0ubuntu1~16.04.1, 3.0.1-0ubuntu1~16.04.2), ...
End-Date: 2018-07-06 14:15:54
