Thanks @stgraber… you are always super awesome for helping out.
lxc info applications --show-log
Remote: unix://
Created: 2020/02/10 11:08 UTC
Status: Running
Type: container
Profiles: default
Pid: 6223
Ips:
eth0: inet 10.60.163.126 vethde4fcc74
eth0: inet6 fd42:d9c2:c4ab:e0ac:216:3eff:fe13:c226 vethde4fcc74
eth0: inet6 fe80::216:3eff:fe13:c226 vethde4fcc74
lo: inet 127.0.0.1
lo: inet6 ::1
Resources:
Processes: 693
Disk usage:
root: 8.16GB
CPU usage:
CPU usage (in seconds): 7142
Memory usage:
Memory (current): 4.48GB
Network usage:
Bytes received: 160.32MB
Bytes sent: 100.69MB
Packets received: 319709
Packets sent: 299948
lo:
Bytes received: 1.71MB
Bytes sent: 1.71MB
Packets received: 19156
Packets sent: 19156
Snapshots:
update (taken at 2020/04/06 02:12 UTC) (stateless)
Log:
lxc applications 20200406021826.923 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1143 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.applications"
lxc applications 20200406021826.924 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1143 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.applications"
lxc applications 20200406021826.924 ERROR utils - utils.c:lxc_can_use_pidfd:1855 - Invalid argument - Kernel does not support waiting on processes through pidfds
lxc applications 20200406021826.927 WARN cgfsng - cgroups/cgfsng.c:fchowmodat:1455 - No such file or directory - Failed to fchownat(17, memory.oom.group, 1000000000, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
Also including lxc config show applications --expanded in case it helps
image.architecture: x86_64
image.description: Ubuntu 19.04 server (20190724)
image.os: ubuntu
image.release: disco
limits.cpu: "2"
limits.memory: 10GB
raw.idmap: both 1000 1000
security.nesting: "true"
volatile.base_image: 1169dae22e484d31cd4056803f56d4aa0c80272a4d776085b67aeb7054aff738
volatile.eth0.host_name: vethde4fcc74
volatile.eth0.hwaddr: 00:16:3e:13:c2:26
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1001001,"Nsid":1001,"Maprange":999998999},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":999998999}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1001001,"Nsid":1001,"Maprange":999998999},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":999998999}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1001001,"Nsid":1001,"Maprange":999998999},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":999998999}]'
PACookie_toochevere:
path: /home/toochevere/.config/pulse/cookie
source: /home/toochevere/.config/pulse/cookie
Xauthority_toochevere:
path: /home/toochevere/.Xauthority
source: /run/user/1000/gdm/Xauthority
Xdisplay:
path: /tmp/.X11-unix/X0
source: /tmp/.X11-unix/X1
commontools:
path: /common-tools
source: /common-tools
nictype: bridged
parent: lxdbr0
home-Documents:
path: /home/toochevere/Documents
source: /home/toochevere/Documents
home-Downloads:
path: /home/toochevere/Downloads
source: /home/toochevere/Downloads
home-Music:
path: /home/toochevere/Music
source: /home/toochevere/Music
home-Pictures:
path: /home/toochevere/Pictures
source: /home/toochevere/Pictures
home-Public:
path: /home/toochevere/Public
source: /home/toochevere/Public
home-Templates:
path: /home/toochevere/Templates
source: /home/toochevere/Templates
home-Videos:
path: /home/toochevere/Videos
source: /home/toochevere/Videos
hostgpu:
gid: "1000"
type: gpu
uid: "1000"
pool: default
video0:
path: /dev/video0
source: /dev/video0
video1:
path: /dev/video1
source: /dev/video1
