All container offline, no outgoing route
Hi
Today i connected to my container an one by one and would like to do some package updates. But no one can get updates, showing only (in case of trying debian 12) a v6 ip, but no new packages. The host is running on debian 12… From the “outside” via proxy i can reach the systems… Whats going on…??
Tnx in adv…
Found it… See >
https://linuxcontainers.org/incus/docs/main/howto/network_bridge_firewalld/#network-incus-docker
You must make this setting persistent across host reboots.
One way of doing this is to add a file to the /etc/sysctl.d/ directory using the following commands:
echo “net.ipv4.conf.all.forwarding=1” > /etc/sysctl.d/99-forwarding.conf
systemctl restart systemd-sysctl
