There are two hard drive in my server. In despite of their existence, Ubuntu doesn’t mount them because of file format issue. So I formatted them to ext4. However, after then, lxc and lxd have both broken. I logged in LXD-UI to check previous instances but all of them have disappeared.
I tried some commands but many of them gave the same error:
lxc start --all
Error: Get “http://unix.socket/1.0”: dial unix /var/snap/lxd/common/lxd/unix.socket: connect: no such file or directory
Then I run debug command:
lxd --debug --group lxd
which outputted an error:
EROR[10-01|14:16:25] Failed to start the daemon err=“Failed initializing storage pool "default": Failed to run: zpool import -f -d /var/snap/lxd/common/lxd/disks default: cannot import ‘default’: no such pool or dataset”
Afterward, I run
systemctl start snap.lxd.daemon.unix.socket
but it doesn’t work. The issues still exist. Those instance image were stored in a ssd not those two formatted hard drive, so I guess those instances are still there.
Does anyone have idea about how to fix this? Any help would be appreciated! Thanks in advance.
