Allow @ in password for OCI registries
With incus version 7.0.1 I get password character @ encoded to %40 at places where it shouldn’t.
The effect is not being able to get images from an OCI registry, e.g. https://dhi.io
Consider this topic a bugreport. If there are better places for such reports, please say so.
Slightly longer problem description:
My (redacted) password is p@ssw0rD, password that has a replaced with @, the o with a zero and the d with a capital D. And I’m using docker-credential-pass.
$ echo https://dhi.io | docker-credential-pass get
{"ServerURL":"https://dhi.io","Username":"account","Secret":"p@ssw0rD"}
With incus launch harder:harbor-portal:2-debian-dev harbor --debug did I capture this:
DEBUG  [2026-08-27T14:23:30+02:00]
		"architecture": "",
		"config": {},
		"devices": {},
		"ephemeral": false,
		"profiles": null,
		"stateful": false,
		"description": "",
		"name": "harbor",
		"source": {
			"type": "image",
			"certificate": "",
			"alias": "harbor-portal:2-debian-dev",
			"server": "https://account:p%40ssw0rD@dhi.io",
			"protocol": "oci",
			"mode": "pull",
			"allow_inconsistent": false
		"instance_type": "",
		"type": "container",
		"start": true
But that incus launch commands bails out with:
Error: Failed instance creation: Failed getting remote \
  image info: Failed to run: skopeo --insecure-policy \
  inspect docker://dhi.io/harbor-portal:2-debian-dev --no-tags \
  --authfile=/var/lib/incus/images/incus_client_auth_261862000: exit status \
  1 (time="2026-08-27T14:23:31+02:00" level=fatal msg="Error parsing \
  image name \"docker://dhi.io/harbor-portal:2-debian-dev\": unable to \
  retrieve auth token: invalid username/password: authentication required")
Zooming in on the authfile reveals {"auths":{"https://dhi.io":{"auth":"YWNjb3VudDpwJTQwc3N3MHJE"}}}.
However the "auth" should be "YWNjb3VudDpwQHNzdzByRA==".
Decoding both "auth" fields:
$ echo YWNjb3VudDpwJTQwc3N3MHJE | base64 -d ; echo
account:p%40ssw0rD
$ echo YWNjb3VudDpwQHNzdzByRA== | base64 -d ; echo
account:p@ssw0rD
The %40 in "server": "https://account:p%40ssw0rD@dhi.io" is valid,
the base64 encoded %40 in {"auth":"YWNjb3VudDpwJTQwc3N3MHJE"} is not valid.
What does incus remote list show, for the OCI remote in question?
Aside: I’ve tested this with a simplestreams server with basic auth, and that works. Seems it’s a problem with OCI stores only.
incus remote add test1 https://test1:p%40ssw0rD@images.example.com/ --protocol simplestreams
incus image list test1:
Stéphane fixed it: incus/oci: Don't URL-escape credentials in skopeo authfile · lxc/incus@87b6d28 · GitHub
This allows “%40” but not “@” in an URL ofc.
For what it is worth: I, Original Poster, don’t know when I will be testing version 7.4.0. Reason is a mix of happy with version 7.0.0 and shy for using packages from “expiremental”.
Anyway: I have the warm feeling that my bugreport has been seen. Thanks!
The fix will make it into 7.0.2 which should release in early October.
FWIW the patch works. \o/
