AlmaLinux and RockyLinux VMs panicking
See AlmaLinux and RockyLinux VM panicking. · Issue #3604 · lxc/incus · GitHub for info. Stephane suggested I post here for additional insight.
Would be useful if you could provide more details on the system itself, especially CPU vendor and model, QEMU version, kernel log output, …
This is a very old document, but still very relevant today: The SIG11 problem
Kernel builds are good at stressing the hardware, and so are running VMs.
I’ve been bitten by this myself in the past. I was able to prove it was a bad DIMM on a 2-DIMM system by running with just one DIMM, and then with just the other.
We need to wait for more details to know, but something else that comes to mind would be some of the new Intel consumer grade chips with a mix of cores. Not all cores may support the same features, so the VM could get re-scheduled over to a different core and then hit some odd issues when specific CPU extensions just disappear.
The kernel should be reasonably smart to avoid that, but it may still be an issue.
Anyway, hard to tell until we know more about the system.
adavis@boss5 (- /1 -) [~] $ lscpu
Architecture:                x86_64
  CPU op-mode(s):            32-bit, 64-bit
  Address sizes:             42 bits physical, 48 bits virtual
  Byte Order:                Little Endian
CPU(s):                      16
  On-line CPU(s) list:       0-15
Vendor ID:                   GenuineIntel
  Model name:                Intel(R) Core(TM) Ultra 7 255H
    CPU family:              6
    Model:                   197
    Thread(s) per core:      1
    Core(s) per socket:      16
    Socket(s):               1
    Stepping:                2
    Microcode version:       0x121
    Frequency boost:         enabled
    CPU(s) scaling MHz:      57%
    CPU max MHz:             2001.0000
    CPU min MHz:             400.0000
    BogoMIPS:                7372.80
    Flags:                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1
                             gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dt
                             es64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave av
                             x f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsb
                             ase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_loc
                             k_detect avx_vnni lam wbnoinvd dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg
                              gfni vaes vpclmulqdq rdpid bus_lock_detect movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities
Virtualization features:
  Virtualization:            VT-x
Caches (sum of all):
  L1d:                       480 KiB (12 instances)
  L1i:                       768 KiB (12 instances)
  L2:                        28 MiB (9 instances)
  L3:                        24 MiB (1 instance)
NUMA:
  NUMA node(s):              1
  NUMA node0 CPU(s):         0-15
Vulnerabilities:
  Gather data sampling:      Not affected
  Ghostwrite:                Not affected
  Indirect target selection: Not affected
  Itlb multihit:             Not affected
  L1tf:                      Not affected
  Mds:                       Not affected
  Meltdown:                  Not affected
  Mmio stale data:           Not affected
  Old microcode:             Not affected
  Reg file data sampling:    Not affected
  Retbleed:                  Not affected
  Spec rstack overflow:      Not affected
  Spec store bypass:         Mitigation; Speculative Store Bypass disabled via prctl
  Spectre v1:                Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:                Vulnerable: eIBRS with unprivileged eBPF
  Srbds:                     Not affected
  Tsa:                       Not affected
  Tsx async abort:           Not affected
  Vmscape:                   Mitigation; IBPB before exit to userspace
Linux boss5.example.org 6.18.38 #1 SMP PREEMPT_DYNAMIC Sat Jul  4 19:11:50 EDT 2026 sx86_64 Intel(R) Core(TM) Ultra 7 255H GenuineIntel GNU/Linux
QEMU version: 10.0.11
64GB RAM. Nothing in the kernel logs.
Okay, so it is a setup with 3 tiers of cores.
You may want to use limits.cpu to pin the VM on just one set of cores to see if that helps.
Weird thing: this issue doesn’t happen with a Debian VM.
Yeah, it probably has some interaction with the guest kernel given that both Alma and Rocky would be on a similar kernel version and config.
I ran the following commands:
incus profile set vm-pcore limits.cpu='0-3'
incus launch images:almalinux/10 vmtest-alma -p agent -p vm-pcore --vm
We’ll see how it goes.
After about 2 hours, it panicked. I ran a memory check; that passed. I’ll run a VM in virt-manager to see if it happens there.
@stgraber When you test VMs, how many vCPUS do you allocate?
The automated image validation runs with just 1 CPU and 1GiB of RAM on 10GiB of disk (Incus defaults).
The Incus pre-release tests use long running VMs and those are more beefy, typically 4 vCPU and 8GB of RAM.
Here’s the relevant output for incus info --resources:
  Cores:
    - Core 0
      Frequency: 1800Mhz
      Threads:
        - 0 (id: 0, online: true, NUMA node: 0)
    - Core 4
      Frequency: 1283Mhz
      Threads:
        - 0 (id: 1, online: true, NUMA node: 0)
    - Core 8
      Frequency: 1529Mhz
      Threads:
        - 0 (id: 6, online: true, NUMA node: 0)
    - Core 9
      Frequency: 1332Mhz
      Threads:
        - 0 (id: 7, online: true, NUMA node: 0)
    - Core 10
      Frequency: 1543Mhz
      Threads:
        - 0 (id: 8, online: true, NUMA node: 0)
    - Core 11
      Frequency: 1315Mhz
      Threads:
        - 0 (id: 9, online: true, NUMA node: 0)
    - Core 12
      Frequency: 1297Mhz
      Threads:
        - 0 (id: 10, online: true, NUMA node: 0)
    - Core 13
      Frequency: 1303Mhz
      Threads:
        - 0 (id: 11, online: true, NUMA node: 0)
    - Core 14
      Frequency: 1300Mhz
      Threads:
        - 0 (id: 12, online: true, NUMA node: 0)
    - Core 15
      Frequency: 1300Mhz
      Threads:
        - 0 (id: 13, online: true, NUMA node: 0)
    - Core 16
      Frequency: 400Mhz
      Threads:
        - 0 (id: 2, online: true, NUMA node: 0)
    - Core 20
      Frequency: 400Mhz
      Threads:
        - 0 (id: 3, online: true, NUMA node: 0)
    - Core 24
      Frequency: 400Mhz
      Threads:
        - 0 (id: 4, online: true, NUMA node: 0)
    - Core 28
      Frequency: 1286Mhz
      Threads:
        - 0 (id: 5, online: true, NUMA node: 0)
    - Core 32
      Frequency: 1568Mhz
      Threads:
        - 0 (id: 14, online: true, NUMA node: 0)
    - Core 33
      Frequency: 1014Mhz
      Threads:
        - 0 (id: 15, online: true, NUMA node: 0)
  Frequency: 1191Mhz (min: 400Mhz, max: 2001Mhz)
Did I choose the correct values for limits.cpu?
Honestly hard to tell from that output.
Can you show incus query /1.0/resources, the full CPU details may be enough to figure it out.
Otherwise I wonder if lscpu would tell us about what core is what.
	"cpu": {
		"architecture": "x86_64",
		"sockets": [
				"address_sizes": {
					"physical_bits": 42,
					"virtual_bits": 48
				"cache": [
						"level": 1,
						"size": 49152,
						"type": "Data"
						"level": 1,
						"size": 65536,
						"type": "Instruction"
						"level": 2,
						"size": 3145728,
						"type": "Unified"
						"level": 3,
						"size": 25165824,
						"type": "Unified"
				"cores": [
						"core": 0,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"tsc_deadline_timer",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"split_lock_detect",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 0,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 4,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 1801,
						"threads": [
								"id": 1,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 8,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 6,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 9,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 3832,
						"threads": [
								"id": 7,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 10,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 3982,
						"threads": [
								"id": 8,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 11,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 9,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 12,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 1427,
						"threads": [
								"id": 10,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 13,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 1467,
						"threads": [
								"id": 11,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 14,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 1307,
						"threads": [
								"id": 12,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 15,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 1376,
						"threads": [
								"id": 13,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 16,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 700,
						"threads": [
								"id": 2,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 20,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 3,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 24,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 4,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 28,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 5,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 32,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 14,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
						"core": 33,
						"die": 0,
						"flags": [
							"fpu",
							"vme",
							"de",
							"pse",
							"tsc",
							"msr",
							"pae",
							"mce",
							"cx8",
							"apic",
							"sep",
							"mtrr",
							"pge",
							"mca",
							"cmov",
							"pat",
							"pse36",
							"clflush",
							"dts",
							"acpi",
							"mmx",
							"fxsr",
							"sse",
							"sse2",
							"ss",
							"ht",
							"tm",
							"pbe",
							"syscall",
							"nx",
							"pdpe1gb",
							"rdtscp",
							"lm",
							"constant_tsc",
							"art",
							"arch_perfmon",
							"pebs",
							"bts",
							"rep_good",
							"nopl",
							"xtopology",
							"nonstop_tsc",
							"cpuid",
							"aperfmperf",
							"tsc_known_freq",
							"pni",
							"pclmulqdq",
							"dtes64",
							"monitor",
							"ds_cpl",
							"vmx",
							"smx",
							"est",
							"tm2",
							"ssse3",
							"sdbg",
							"fma",
							"cx16",
							"xtpr",
							"pdcm",
							"pcid",
							"sse4_1",
							"sse4_2",
							"x2apic",
							"movbe",
							"popcnt",
							"aes",
							"xsave",
							"avx",
							"f16c",
							"rdrand",
							"lahf_lm",
							"abm",
							"3dnowprefetch",
							"cpuid_fault",
							"epb",
							"ssbd",
							"ibrs",
							"ibpb",
							"stibp",
							"ibrs_enhanced",
							"tpr_shadow",
							"flexpriority",
							"ept",
							"vpid",
							"ept_ad",
							"fsgsbase",
							"tsc_adjust",
							"bmi1",
							"avx2",
							"smep",
							"bmi2",
							"erms",
							"invpcid",
							"rdseed",
							"adx",
							"smap",
							"clflushopt",
							"clwb",
							"intel_pt",
							"sha_ni",
							"xsaveopt",
							"xsavec",
							"xgetbv1",
							"xsaves",
							"avx_vnni",
							"lam",
							"wbnoinvd",
							"dtherm",
							"ida",
							"arat",
							"pln",
							"pts",
							"hwp",
							"hwp_notify",
							"hwp_act_window",
							"hwp_epp",
							"hwp_pkg_req",
							"hfi",
							"vnmi",
							"umip",
							"pku",
							"ospke",
							"waitpkg",
							"gfni",
							"vaes",
							"vpclmulqdq",
							"rdpid",
							"bus_lock_detect",
							"movdiri",
							"movdir64b",
							"fsrm",
							"md_clear",
							"serialize",
							"arch_lbr",
							"ibt",
							"flush_l1d",
							"arch_capabilities"
						"frequency": 400,
						"threads": [
								"id": 15,
								"isolated": false,
								"numa_node": 0,
								"online": true,
								"thread": 0
				"frequency": 1193,
				"frequency_minimum": 400,
				"frequency_turbo": 2001,
				"name": "Intel(R) Core(TM) Ultra 7 255H",
				"socket": 0,
				"vendor": "GenuineIntel"
		"total": 16
	"gpu": {
		"cards": [
				"driver": "i915",
				"driver_version": "6.18.38",
				"drm": {
					"card_device": "226:0",
					"card_name": "card0",
					"control_device": "226:0",
					"control_name": "controlD64",
					"id": 0,
					"render_device": "226:128",
					"render_name": "renderD128"
				"numa_node": 0,
				"pci_address": "0000:00:02.0",
				"product": "Arrow Lake-P [Arc Pro 130T/140T]",
				"product_id": "7d51",
				"sriov": {
					"current_vfs": 0,
					"maximum_vfs": 7,
					"vfs": null
				"vendor": "Intel Corporation",
				"vendor_id": "8086"
		"total": 1
	"load": {
		"Average10Min": 0.38,
		"Average1Min": 0,
		"Average5Min": 0.07,
		"Processes": 520
	"memory": {
		"hugepages_size": 2097152,
		"hugepages_total": 0,
		"hugepages_used": 0,
		"nodes": [
				"numa_node": 0,
				"total": 68719476736,
				"used": 57416105984
		"used": 14203113472
	"network": {
		"cards": [
				"driver": "e1000e",
				"firmware_version": "1.1-4",
				"numa_node": 0,
				"pci_address": "0000:00:1f.6",
				"ports": [
						"address": "d4:93:90:57:31:3a",
						"auto_negotiation": true,
						"id": "eth0",
						"link_detected": false,
						"port": 0,
						"port_type": "twisted pair",
						"protocol": "ethernet",
						"supported_modes": [
							"10baseT/Half",
							"10baseT/Full",
							"100baseT/Half",
							"100baseT/Full",
							"1000baseT/Full"
						"supported_ports": [
							"twisted pair"
						"transceiver_type": "internal"
				"product": "Ethernet Connection (18) I219-LM",
				"product_id": "550a",
				"vendor_id": "8086"
				"driver": "iwlwifi",
				"firmware_version": "101.6ef20b19.0 gl-c0-fm-c0-101.",
				"numa_node": 0,
				"pci_address": "0000:2f:00.0",
				"ports": [
						"address": "44:a3:bb:bb:58:e1",
						"auto_negotiation": false,
						"id": "wlan0",
						"link_detected": true,
						"port": 0,
				"product": "Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2",
				"product_id": "272b",
				"vendor_id": "8086"
		"total": 2
	"pci": {
		"devices": [
				"driver": "",
				"driver_version": "",
				"iommu_group": 1,
				"numa_node": 0,
				"pci_address": "0000:00:00.0",
				"product": "Core Ultra 200H Series Processors with 6 P-Cores 8 E-Cores Host Bridge",
				"product_id": "7d06",
				"vendor_id": "8086",
				"vpd": {}
				"driver": "i915",
				"iommu_group": 0,
				"numa_node": 0,
				"vpd": {}
				"driver": "pcieport",
				"iommu_group": 2,
				"numa_node": 0,
				"pci_address": "0000:00:06.0",
				"product": "Core Ultra 200 Series Processors PCIe Root Port #10",
				"product_id": "7eca",
				"vpd": {}
				"iommu_group": 3,
				"numa_node": 0,
				"pci_address": "0000:00:06.2",
				"product": "Core Ultra 200H/200V Series Processors PCIe Root Port #11 (PXPE)",
				"product_id": "7ecb",
				"vpd": {}
				"iommu_group": 4,
				"numa_node": 0,
				"pci_address": "0000:00:07.0",
				"product": "Core Ultra 200 Series Processors USB Type-C Subsystem PCIe Root Port #16",
				"product_id": "7ec4",
				"vpd": {}
				"driver": "",
				"iommu_group": 5,
				"numa_node": 0,
				"pci_address": "0000:00:0a.0",
				"product": "Core Ultra 200H/200V Series Processors Platform Monitoring Technology (PMT)",
				"product_id": "7d0d",
				"vpd": {}
				"driver": "",
				"iommu_group": 6,
				"numa_node": 0,
				"pci_address": "0000:00:0b.0",
				"product": "Core Ultra 200H/200V Series Processors NPU",
				"product_id": "7d1d",
				"vpd": {}
				"driver": "xhci_hcd",
				"iommu_group": 7,
				"numa_node": 0,
				"pci_address": "0000:00:0d.0",
				"product": "Core Ultra 200 Series Processors USB xHCI",
				"product_id": "7ec0",
				"vpd": {}
				"driver": "thunderbolt",
				"iommu_group": 7,
				"numa_node": 0,
				"pci_address": "0000:00:0d.2",
				"product": "Core Ultra 200 Series Processors Thunderbolt DMA0",
				"product_id": "7ec2",
				"vpd": {}
				"iommu_group": 8,
				"numa_node": 0,
				"pci_address": "0000:00:14.0",
				"product": "Core Ultra 200H/200V Series Processors Standalone xHCI Controller",
				"product_id": "777d",
				"vpd": {}
				"driver": "",
				"iommu_group": 8,
				"numa_node": 0,
				"pci_address": "0000:00:14.2",
				"product": "Core Ultra 200H/200V Series Processors Shared SRAM",
				"product_id": "777f",
				"vpd": {}
				"driver": "intel-lpss",
				"iommu_group": 9,
				"numa_node": 0,
				"pci_address": "0000:00:15.0",
				"product": "Core Ultra 200H/200V Series Processors I2C #0",
				"product_id": "7778",
				"vpd": {}
				"iommu_group": 9,
				"numa_node": 0,
				"pci_address": "0000:00:15.1",
				"product": "Core Ultra 200H/200V Series Processors I2C #1",
				"product_id": "7779",
				"vpd": {}
				"iommu_group": 10,
				"numa_node": 0,
				"pci_address": "0000:00:1c.0",
				"product": "Core Ultra 200H/200V Series Processors PCIe Root Port #6",
				"product_id": "773d",
				"vpd": {}
				"iommu_group": 11,
				"numa_node": 0,
				"pci_address": "0000:00:1c.7",
				"product": "Core Ultra 200H/200V Series Processors PCIe Root Port #8",
				"product_id": "773f",
				"vpd": {}
				"driver": "",
				"iommu_group": 12,
				"numa_node": 0,
				"pci_address": "0000:00:1f.0",
				"product": "Arrow Lake-H eSPI Controller",
				"product_id": "7702",
				"vpd": {}
				"driver": "snd_hda_intel",
				"iommu_group": 12,
				"numa_node": 0,
				"pci_address": "0000:00:1f.3",
				"product": "Core Ultra 200H/200V Series Processors HD Audio",
				"product_id": "7728",
				"vpd": {}
				"driver": "i801_smbus",
				"iommu_group": 12,
				"numa_node": 0,
				"pci_address": "0000:00:1f.4",
				"product": "Core Ultra 200H/200V Series Processors SMBus",
				"product_id": "7722",
				"vpd": {}
				"driver": "intel-spi",
				"iommu_group": 12,
				"numa_node": 0,
				"pci_address": "0000:00:1f.5",
				"product": "Core Ultra 200H/200V Series Processors SPI (flash) Controller",
				"product_id": "7723",
				"vpd": {}
				"driver": "e1000e",
				"iommu_group": 12,
				"numa_node": 0,
				"vpd": {}
				"driver": "nvme",
				"driver_version": "1.0",
				"iommu_group": 13,
				"numa_node": 0,
				"pci_address": "0000:01:00.0",
				"product": "NVMe SSD Controller S4LV008[Pascal]",
				"product_id": "a80c",
				"vendor": "Samsung Electronics Co Ltd",
				"vendor_id": "144d",
				"vpd": {}
				"driver": "nvme",
				"iommu_group": 14,
				"numa_node": 0,
				"pci_address": "0000:02:00.0",
				"product": "Platinum P41/PC801 NVMe Solid State Drive",
				"product_id": "1959",
				"vendor": "SK hynix",
				"vendor_id": "1c5c",
				"vpd": {}
				"driver": "sdhci-pci",
				"iommu_group": 15,
				"numa_node": 0,
				"pci_address": "0000:2e:00.0",
				"product": "OZ711 SD/MMC Card Reader Controller",
				"product_id": "8621",
				"vendor": "O2 Micro, Inc.",
				"vendor_id": "1217",
				"vpd": {}
				"iommu_group": 16,
				"numa_node": 0,
				"vpd": {}
		"total": 24
	"serial": {
		"devices": [],
		"total": 0
	"storage": {
		"disks": [
				"block_size": 512,
				"device": "259:0",
				"device_id": "nvme-eui.002538425141003a",
				"firmware_version": "5B2QJXD7",
				"id": "nvme0n1",
				"model": "Samsung SSD 990 PRO 2TB",
				"numa_node": 0,
				"partitions": [
						"device": "259:1",
						"id": "nvme0n1p1",
						"partition": 1,
						"read_only": false,
						"size": 1023410176
						"device": "259:2",
						"id": "nvme0n1p2",
						"partition": 2,
						"read_only": false,
						"size": 1999374385152
				"read_only": false,
				"removable": false,
				"rpm": 0,
				"serial": "S7L9NJ0Y213669Y",
				"size": 2000398934016,
				"type": "nvme",
				"wwn": "eui.002538425141003a"
				"block_size": 512,
				"device": "259:3",
				"device_id": "nvme-eui.ace42e00352e16cf2ee4ac0000000001",
				"firmware_version": "51060A20",
				"id": "nvme1n1",
				"model": "SHPP41-2000GM",
				"numa_node": 0,
				"partitions": [
						"device": "259:4",
						"id": "nvme1n1p1",
						"partition": 1,
						"read_only": false,
						"size": 134217728
						"device": "259:5",
						"id": "nvme1n1p2",
						"partition": 2,
						"read_only": false,
						"size": 2000263577600
				"read_only": false,
				"removable": false,
				"rpm": 0,
				"serial": "SDC3N40191040334M",
				"type": "nvme",
				"wwn": "eui.ace42e00352e16cf2ee4ac0000000001"
		"total": 6
	"system": {
		"chassis": {
			"serial": "",
			"type": "Laptop",
			"vendor": "System76",
			"version": ""
		"family": "",
		"firmware": {
			"date": "04/03/2025",
			"vendor": "coreboot",
			"version": "2025-04-03_04c4e20"
		"motherboard": {
			"product": "Darter Pro",
			"serial": "123456789",
			"version": "darp11"
		"sku": "",
		"type": "unknown",
		"uuid": "",
		"version": "darp11"
	"usb": {
		"devices": [
				"bus_address": 3,
				"device_address": 4,
				"interfaces": [
						"class": "",
						"class_id": 224,
						"driver": "btusb",
						"driver_version": "0.8",
						"number": 0,
						"subclass": "",
						"subclass_id": 1
						"class": "",
						"class_id": 224,
						"driver": "btusb",
						"number": 1,
						"subclass": "",
						"subclass_id": 1
				"product": "",
				"product_id": "0036",
				"serial": "",
				"speed": 12,
				"vendor": "",
				"vendor_id": "8087"
				"bus_address": 3,
				"device_address": 2,
				"interfaces": [
						"class": "",
						"class_id": 14,
						"driver": "uvcvideo",
						"driver_version": "1.1.1",
						"number": 0,
						"subclass": "",
						"subclass_id": 1
						"class": "",
						"class_id": 14,
						"number": 1,
						"subclass": "",
						"subclass_id": 2
						"class": "",
						"class_id": 254,
						"driver": "",
						"number": 2,
						"subclass": "",
						"subclass_id": 1
				"product": "Chicony USB2.0 Camera",
				"product_id": "b729",
				"serial": "",
				"speed": 480,
				"vendor": "",
				"vendor_id": "04f2"
		"total": 2
# lscpu
CPU(s):                      16
    CPU family:              6
    Model:                   197
    Socket(s):               1
    Stepping:                2
    CPU(s) scaling MHz:      35%
    BogoMIPS:                7372.80
    Flags:                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_
                             tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sd
                             bg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs
                             ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt
                              sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect avx_vnni lam wbnoinvd dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi v
                             nmi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid bus_lock_detect movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities
NUMA:
  NUMA node(s):              1
Vulnerabilities:
  L1tf:                      Not affected
  Mds:                       Not affected
  Srbds:                     Not affected
  Tsa:                       Not affected
Ran Rocky Linux 10.2 on virt-manager with the same resources: the VM ran for nearly 8 hours with no issues. I even built the kernel from source. Will test Alma Linux later this evening.
Used an LLM on the data to identify things based on CPU flags and core IDs, that gave me:
Core type Physical core IDs Thread IDs
P-cores (Lion Cove, 6) 0, 4, 16, 20, 24, 28 0, 1, 2, 3, 4, 5
E-cores (Skymont, 8) 8–15 (two clusters of 4) 6, 7, 8, 9, 10, 11, 12, 13
LP E-cores (2) 32, 33 14, 15
So no weird interleaving as we see when SMT is present or on multi-socket systems.
Your 0-3 should all have been P cores. It could be useful to get the full QEMU command line from libvirt so we can see if anything stands out that could explain the difference.
Rocky Linus worked w/o issue. Here is the QEMU command:
/opt/qemu-10.0/bin/qemu-system-x86_64 -name guest=rocky10.2,debug-threads=on -S -object {"qom-type":"secret","id":"masterKey0","format":"raw","file":"/home/adavis/.config/libvirt/qemu/lib/domain-3-rocky10.2/master-key.aes"} -machine pc-q35-10.0,usb=off,vmport=off,dump-guest-core=off,memory-backend=pc.ram,hpet=off,acpi=on -accel kvm -cpu host,migratable=on -m size=8388608k -object {"qom-type":"memory-backend-ram","id":"pc.ram","size":8589934592} -overcommit mem-lock=off -smp 4,sockets=4,cores=1,threads=1 -uuid 198be6d3-56c5-4f62-b401-7bcd5dac2184 -no-user-config -nodefaults -chardev socket,id=charmonitor,fd=28,server=on,wait=off -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-shutdown -global ICH9-LPC.disable_s3=1 -global ICH9-LPC.disable_s4=1 -boot strict=on -device {"driver":"pcie-root-port","port":16,"chassis":1,"id":"pci.1","bus":"pcie.0","multifunction":true,"addr":"0x2"} -device {"driver":"pcie-root-port","port":17,"chassis":2,"id":"pci.2","bus":"pcie.0","addr":"0x2.0x1"} -device {"driver":"pcie-root-port","port":18,"chassis":3,"id":"pci.3","bus":"pcie.0","addr":"0x2.0x2"} -device {"driver":"pcie-root-port","port":19,"chassis":4,"id":"pci.4","bus":"pcie.0","addr":"0x2.0x3"} -device {"driver":"pcie-root-port","port":20,"chassis":5,"id":"pci.5","bus":"pcie.0","addr":"0x2.0x4"} -device {"driver":"pcie-root-port","port":21,"chassis":6,"id":"pci.6","bus":"pcie.0","addr":"0x2.0x5"} -device {"driver":"pcie-root-port","port":22,"chassis":7,"id":"pci.7","bus":"pcie.0","addr":"0x2.0x6"} -device {"driver":"pcie-root-port","port":23,"chassis":8,"id":"pci.8","bus":"pcie.0","addr":"0x2.0x7"} -device {"driver":"pcie-root-port","port":24,"chassis":9,"id":"pci.9","bus":"pcie.0","multifunction":true,"addr":"0x3"} -device {"driver":"pcie-root-port","port":25,"chassis":10,"id":"pci.10","bus":"pcie.0","addr":"0x3.0x1"} -device {"driver":"pcie-root-port","port":26,"chassis":11,"id":"pci.11","bus":"pcie.0","addr":"0x3.0x2"} -device {"driver":"pcie-root-port","port":27,"chassis":12,"id":"pci.12","bus":"pcie.0","addr":"0x3.0x3"} -device {"driver":"pcie-root-port","port":28,"chassis":13,"id":"pci.13","bus":"pcie.0","addr":"0x3.0x4"} -device {"driver":"pcie-root-port","port":29,"chassis":14,"id":"pci.14","bus":"pcie.0","addr":"0x3.0x5"} -device {"driver":"qemu-xhci","p2":15,"p3":15,"id":"usb","bus":"pci.2","addr":"0x0"} -device {"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.3","addr":"0x0"} -blockdev {"driver":"file","filename":"/spare/home/adavis/.local/share/libvirt/images/rocky10.2.qcow2","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"} -blockdev {"node-name":"libvirt-2-format","read-only":false,"discard":"unmap","driver":"qcow2","file":"libvirt-2-storage","backing":null} -device {"driver":"virtio-blk-pci","bus":"pci.4","addr":"0x0","drive":"libvirt-2-format","id":"virtio-disk0","bootindex":1} -device {"driver":"ide-cd","bus":"ide.0","id":"sata0-0-0"} -netdev {"type":"user","id":"hostnet0"} -device {"driver":"virtio-net-pci","netdev":"hostnet0","id":"net0","mac":"52:54:00:4a:ca:d1","bus":"pci.1","addr":"0x0"} -chardev pty,id=charserial0 -device {"driver":"isa-serial","chardev":"charserial0","id":"serial0","index":0} -chardev socket,id=charchannel0,fd=27,server=on,wait=off -device {"driver":"virtserialport","bus":"virtio-serial0.0","nr":1,"chardev":"charchannel0","id":"channel0","name":"org.qemu.guest_agent.0"} -chardev spicevmc,id=charchannel1,name=vdagent -device {"driver":"virtserialport","bus":"virtio-serial0.0","nr":2,"chardev":"charchannel1","id":"channel1","name":"com.redhat.spice.0"} -device {"driver":"usb-tablet","id":"input0","bus":"usb.0","port":"1"} -audiodev {"id":"audio1","driver":"spice"} -spice port=5901,addr=127.0.0.1,disable-ticketing=on,image-compression=off,seamless-migration=on -device {"driver":"virtio-vga","id":"video0","max_outputs":1,"bus":"pcie.0","addr":"0x1"} -device {"driver":"ich9-intel-hda","id":"sound0","bus":"pcie.0","addr":"0x1b"} -device {"driver":"hda-duplex","id":"sound0-codec0","bus":"sound0.0","cad":0,"audiodev":"audio1"} -global ICH9-LPC.noreboot=off -watchdog-action reset -chardev spicevmc,id=charredir0,name=usbredir -device {"driver":"usb-redir","chardev":"charredir0","id":"redir0","bus":"usb.0","port":"2"} -chardev spicevmc,id=charredir1,name=usbredir -device {"driver":"usb-redir","chardev":"charredir1","id":"redir1","bus":"usb.0","port":"3"} -device {"driver":"virtio-balloon-pci","id":"balloon0","bus":"pci.5","addr":"0x0"} -object {"qom-type":"rng-random","id":"objrng0","filename":"/dev/urandom"} -device {"driver":"virtio-rng-pci","rng":"objrng0","id":"rng0","bus":"pci.6","addr":"0x0"} -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny -msg timestamp=on
Incus would have given you a 4 cores system whereas libvirt is giving you a 4 sockets single core system. No idea if that matters, but you could try limits.cpu=sockets=4 to get the same layout.
Other than that, it’s doing a few things differently as far as the q35 machine itself, specifically:
  • vmport=off
  • dump-guest-core=off
  • hpet=off
  • acpi=on
Not sure how many of those are relevant vs are the default value anyway (ACPI at least is).
I found out that running QEMU with NUMA not built in, stops the panics: the VM has been up for 2 days. Of course that disables pinning. I’m going to try the following with NUMA built in:
  1. Booting the host with NUMA=off (it’s not a true NUMA server; it’s using emulation mode).
  2. Running the VM with limits.cpu.nodes = 0.
I can reliably panic the VM by running ‘fwupdmgr refresh’ in a VM with NUMA enabled. In virt–manager, NUMA is disabled by default, hence no crash. Incus creates a NUMA node by default. Is there a way to have incus not create a NUMA configuration stanza in the configuration file?
