I’m having a strange (and annoying) issue with all my Alpine Linux containers (various versions): The log entries in /var/log/messages all show a timestamp of “Dec 31 23:59:59”.
Is this a known issue? Is anyone else experiencing this?
I’m not sure how to track this one down, so any help would be appreciated.
I’ve never heard of this before so it’s certainly a new one for us
Can you confirm that running date inside your container shows a reasonable timestamp?
If so, then it’s likely the syslog logger in Alpine doing something funny to grab its time or timezone.
Its a known bug in Alpine.
You can comment out SYSLOGD_OPTS="-Z" in /etc/conf.d/syslog so you get at least working UTC times (without local time shift) instead of fixed timestamps.
@stgraber: I don’t know what this project’s policy is concerning upstream bugs in the images you provide. Should I file an issue on the lxc/lxd github tracker? After all it’d be a rather simple fix.
And there’s a second annoying logging bug:
$ lxc launch images:alpine/edge test
Creating test
Starting test
$ lxc exec test tail /var/log/messages
Dec 31 23:59:59 test daemon.info init: can't open /dev/tty3: No such file or directory
Dec 31 23:59:59 test daemon.info init: can't open /dev/tty4: No such file or directory
Dec 31 23:59:59 test daemon.info init: process '/sbin/getty 38400 tty1' (pid 973) exited. Scheduling for restart.
Dec 31 23:59:59 test daemon.info init: process '/sbin/getty 38400 tty2' (pid 974) exited. Scheduling for restart.
Dec 31 23:59:59 test daemon.info init: process '/sbin/getty 38400 tty3' (pid 975) exited. Scheduling for restart.
Dec 31 23:59:59 test daemon.info init: process '/sbin/getty 38400 tty4' (pid 976) exited. Scheduling for restart.
Dec 31 23:59:59 test daemon.info init: can't open /dev/tty1: No such file or directory
Dec 31 23:59:59 test daemon.info init: can't open /dev/tty2: No such file or directory
The solution for this constant syslog spamming is just as simple: comment out the 4 tty lines in /etc/inittab.
I guess I’ll just go ahead and file the 2 bug reports. Anyway, the last few months I’ve been containerizing more and more of my servers, daemons, etc.
Using LXD has been both a revelation and a revolution in how I’m handling those admin tasks. Thanks!
