I was wondering if anyone had any experience running LXD containers on Amazon Linux 2023?
I’ve not got access to EC2 currently so I was hoping if somebody would be happy to knowledge share.
Apparently its based around Fedora not doesn’t support EPEL repos…
I couldn’t find snapd on the package list.
I assume that means having to download and install the static tarball?
Cheers in advance
Simon
You can check this out: https://github.com/albuild/snap (it’s kind of old though)
Then, after following the instructions, can you try:
sudo snap install lxd
And see if it works ?
Thanks but it doesn’t work on Amazon Linux 2023 which is Fedora based as it seems to be built for Amazon Linux 2 which is RHEL based.
However I’ll have a go at building snap myself on amazon line 2023 that seems like a more elegant solution than building LXD myself and missing the update/versioning functionality.
