I’ve tried to start an unprivileged LXC container on Debian-bullseye (still not released as stable) same as I do with Debian 10 (buster/stable).
When I use Debian 10 I’m using LXC 3.0.3 (from buster repositories)
When I use Debian 11 I’m using LXC 4.0.6 (from bullseye repositories)
This is the log when starting either Debian 10 or Debian 11 container with LXC 4:
lxc-start vps1 20210310125921.881 INFO start - start.c:lxc_init:837 - Container "vps1" is initialized
lxc-start vps1 20210310125921.881 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - Permission denied - Failed to create directory "/sys/fs/cgroup/user.slice/user-1000.slice/session-3.scope/lxc.monitor.vps1"
lxc-start vps1 20210310125921.881 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - Permission denied - Failed to create directory "/sys/fs/cgroup/user.slice/user-1000.slice/session-3.scope/lxc.monitor.vps1-1"
(1000 identical lines)
lxc-start vps1 20210310125921.894 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - Permission denied - Failed to create directory "/sys/fs/cgroup/user.slice/user-1000.slice/session-3.scope/lxc.monitor.vps1-999"
lxc-start vps1 20210310125921.894 ERROR cgfsng - cgroups/cgfsng.c:cgfsng_monitor_create:1365 - Numerical result out of range - Failed to create monitor cgroup
lxc-start vps1 20210310125921.894 ERROR start - start.c:__lxc_start:1960 - Failed to create monitor cgroup
lxc-start vps1 20210310125921.894 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:859 - Received container state "ABORTING" instead of "RUNNING"
lxc-start vps1 20210310125921.894 ERROR lxc_start - tools/lxc_start.c:main:308 - The container failed to start
lxc-start vps1 20210310125921.894 ERROR lxc_start - tools/lxc_start.c:main:311 - To get more details, run the container in foreground mode
lxc-start vps1 20210310125921.894 ERROR lxc_start - tools/lxc_start.c:main:313 - Additional information can be obtained by setting the --logfile and --logpriority options
lxc-start vps1 20210310125921.895 INFO utils - utils.c:get_rundir:260 - XDG_RUNTIME_DIR isn't set in the environment
lxc-start vps1 20210310125921.898 NOTICE utils - utils.c:lxc_setgroups:1420 - Dropped additional groups
lxc-start vps1 20210310125921.898 INFO utils - utils.c:get_rundir:260 - XDG_RUNTIME_DIR isn't set in the environment
lxc-start vps1 20210310125921.898 INFO conf - conf.c:run_script_argv:330 - Executing script "/usr/share/lxcfs/lxc.reboot.hook" for container "vps1", config section "lxc"
(I don’t know what XDG has to do here if it’s a CLI system)
This is the “config” file content:
lxc.arch = linux64
lxc.include = /etc/lxc/default.conf
lxc.apparmor.profile = unconfined
lxc.idmap = u 0 231072 65536
lxc.idmap = g 0 231072 65536
lxc.autodev = 1
lxc.mount.entry = /dev/fuse dev/fuse none bind,optional,rw,create=file 0 0
lxc.rootfs.path = dir:/home/lxc/.local/share/lxc/vps1/rootfs
lxc.uts.name = vps1
lxc.net.0.type = veth
lxc.net.0.link = lanbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3E:E3:c6:80
