Is there any resource usage differences between running the benchmark command directly within the LXD container image versus running the command via lxc exec image-name -- cmd ?
Is it more accurate to run the benchmark commands within the LXD container as opposed to via lxc exec command ?
$ cat bench.sh
#!/bin/bash
for i in `seq 1 100`;
do
lxc exec mycontainer uptime 1&>/dev/null
done
$ time bash bench.sh
Elapsed time : 0m8.382s
User mode : 0m1.640s
System mode : 0m1.269s
CPU percentage : 34.70
$ lxc exec mycontainer -- sudo --user ubuntu --login
ubuntu@mycontainer:~$ cat bench.sh
#!/bin/bash
do
uptime 1&>/dev/null
done
ubuntu@mycontainer:~$ time bash bench.sh
|real|0m0.242s|
|user|0m0.133s|
|sys|0m0.086s|
That means that in this case, it takes about 80ms to do the lxc exec.
Depending on the benchmark, if you are measuring processes that take several minutes,
then it does not matter much to lose 80ms with lxc exec.
I would consider a fair way to conduct the benchmark, is by:
