Any gotchas to consider when running OpenWrt in container?
I’m tinkering with OpenWrt in both containers and a custom built VM. Both appear to work as expected, which probably means I’m missing something :sweat_smile:
Can anyone (maybe @simos ?) point out any compromises when running a vanilla OpenWrt install (current version) in a container vs VM?
i.e. anything that just doesn’t work as intended
The main gotchas I’ve run into:
**Kernel modules**: The container shares your host kernel, so OpenWrt’s kmod-* packages won’t work unless the host kernel already has those modules. Hardware-specific offloading, custom drivers, that sort of thing is out.
**Network interfaces**: You need to explicitly pass through physical interfaces (via macvlan, ipvlan, or phys device type in Incus). OpenWrt expects to own its WAN and LAN interfaces. It won’t just see the container’s default eth0 as a real NIC.
**Capabilities**: The container needs NET_ADMIN at minimum for nftables rules to work. In Incus this usually means `security.privileged=true` or adding the capability explicitly. Without it, OpenWrt’s firewall startup will fail silently.
**What works fine**: dnsmasq (DNS/DHCP), nftables filtering within the container’s network namespace, the luci web interface, most OpenWrt packages that don’t touch hardware directly.
**What doesn’t work well**: Hardware offloading, SQM/QoS that relies on kernel schedulers, anything needing SYS_MODULE capability, bridge VLAN filtering at the hardware level.
In my experience containers are great if you’re using OpenWrt mainly as a DNS/DHCP server or software firewall in a lab. For actual router duties with real traffic shaping on physical interfaces, the VM route is more predictable.
That’s tremendously helpful. Thank you for the clear breakdown. I would probably have not noticed the non-functional firewall until waaaay too late :wink:
Are you sure ip/nftables doesn’t work in containers?
It seems to work based on this posts and some quick testing. Although, I am not passing through physical devices so that might be it?
Yeah, iptables/nftables definitely work just fine in unprivileged containers.
They do net CAP_NET_ADMIN but they check for that capability against the network namespace and not against the entire kernel. Root in an unprivileged container absolutely has CAP_NET_ADMIN against its own network namespace.
For anyone coming across this thread, this other thread is also helpful:
https://discuss.linuxcontainers.org/t/openwrt-testing-in-incus/25763/6
tl;dr Anything kernel-related is not suitable for a container, use a VM instead; work to support incus agent for OpenWRT VM is in the works as at time of writing
