Hi all
Trying to install a VM, on kvm inside lxc ubuntu 20 container, but the apparmor kernel module from the main host is causing issues.
May 20 09:25:08 oshift dnsmasq[1069]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
May 20 09:32:55 oshift libvirtd[149]: libvirt version: 6.0.0, package: 0ubuntu8 (William Grant wgrant@ubuntu.com Sat, 18 Apr 2020 13:59:21 +1000)
May 20 09:32:55 oshift libvirtd[149]: hostname: oshift
May 20 09:32:55 oshift libvirtd[149]: internal error: Child process (LIBVIRT_LOG_OUTPUTS=3:stderr /usr/lib/libvirt/virt-aa-helper -c -u libvirt-815f1ad8-b426-4976-b14a-16c2a01c48ea) unexpected exit status 1: 2020-05-20 09:32:55.870+0000: 1234: info : libvirt version: 6.0.0, package: 0ubuntu8 (William Grant wgrant@ubuntu.com Sat, 18 Apr 2020 13:59:21 +1000)#0122020-05-20 09:32:55.870+0000: 1234: info : hostname: oshift#0122020-05-20 09:32:55.870+0000: 1234: error : virStorageFileBackendFileRead:128 : Failed to open file ‘/home/ubuntu/.crc/machines/crc/crc’: Permission denied#012virt-aa-helper: error: apparmor_parser exited with error
May 20 09:32:55 oshift libvirtd[149]: internal error: cannot load AppArmor profile ‘libvirt-815f1ad8-b426-4976-b14a-16c2a01c48ea’
May 20 09:32:55 oshift systemd[1]: Started Virtual machine log manager.
May 20 09:32:55 oshift libvirtd[149]: End of file while reading data: Input/output error
lxc profile below:
config: limits.memory.swap: "false" linux.kernel_modules: nf_nat,ip_tables,ip6_tables,kvm,kvm_intel,openvswitch,tap,vhost,vhost_net,vhost_scsi,vhost_vsock,netlink_diag,br_netfilter,xt_conntrack,nf_conntrack,ip_vs,ip_vs_rr,ip_vs_wrr,ip_vs_sh,overlay,vxlan raw.lxc: "lxc.apparmor.profile=unconfined\nlxc.cap.drop= \nlxc.cgroup.devices.allow=a\nlxc.mount.auto=proc:rw sys:rw" security.nesting: "true" security.privileged: "true" description: oshift LXD br0 profile devices: eth0: name: eth0 nictype: bridged parent: br0 type: nic kvm: path: /dev/kvm type: unix-char root: path: / pool: default type: disk tun: path: /dev/net/tun type: unix-char vhost-net: mode: "0600" path: /dev/vhost-net type: unix-char vhost-scsi: mode: "0600" path: /dev/vhost-scsi type: unix-char vhost-vsock: path: /dev/vhost-vsock type: unix-char
Have tried on centos 7 image, but same issue. No apparmor installed, however lxd main host is enforcing eventhough lxc.apparmor.profile=unconfined is set in profile.
Appreciate any direction here.
Edit: Apparmor enforcing via LXD host
sudo cat /sys/kernel/security/apparmor/profiles lxd-oshift_</var/snap/lxd/common/lxd> (enforce) docker-default (enforce) lxd-pminion_</var/snap/lxd/common/lxd> (enforce) libvirt-487a891d-285b-407e-9fa7-4470dfdbd2c6 (enforce)
