The following packages will be upgraded:
incus incus-client
2 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 85.4 MB of archives.
dpkg: warning: unable to delete old directory ‘/var/log/incus’: Directory not empty
dpkg: warning: unable to delete old directory ‘/var/lib/incus’: Directory not empty
Unpacking incus-client (0.5-202401260134-ubuntu20.04) over (0.4-202312232117-ubuntu20.04) …
Selecting previously unselected package incus-base.
Preparing to unpack …/incus-base_0.5-202401260134-ubuntu20.04_amd64.deb …
Unpacking incus-base (0.5-202401260134-ubuntu20.04) …
Setting up nftables (0.9.3-2) …
Setting up incus-client (0.5-202401260134-ubuntu20.04) …
Setting up incus-base (0.5-202401260134-ubuntu20.04) …
Progress: [ 76%] [####################################################################################…]
[1]+ Stopped apt
upgrade#############################################################…]
And then nothing works on upgraded nodes.
I have to manually kill it
Tried redoing apt upgrade, always gets stuck there.
And you made sure to run it on all nodes at the same time?
This is a version update from 0.4 to 0.5, so the upgrade will remain stuck until all servers in the cluster reach the same point, at which point they’ll all unblock.
It worked, they recovered themselves after the last one was updated.
Anyway, it would be nice if Incus update was somehow separate than regular upgrade. It makes me nervous when 8 servers get stuck on upgrade
Also some other ideas/question.
How can I disable ipv6 from present containers, from them ever showing up again.
It would be nice if Containers had a description field like Servers do
