Is it possible to use a Ampere ultra 128 core server to run LXD on a Ubuntu 20.04 server. has anybody tried this already.
also wondering if I was to build a Ubuntu server with LXD and use it to host workstations for thins like Linux distributions and all sorts of usual desktop apps will it perform as well as if I used X86 CPU.
I suppose you will be using some baremetal server from a hosting provider with the Ampere hardware. You can test these out first, by getting a VPS that is based on the Ampere architecture. Hetzner has an inexpensive VPS that is based on the Ampere Altra, https://www.hetzner.com/cloud/
