Hi All,
I encountered an arp cache exceeded limit:
Output of dmesg:
[11474143.315539] neighbour: arp_cache: neighbor table overflow!
[11474143.316565] neighbour: arp_cache: neighbor table overflow!
[11474143.317507] neighbour: arp_cache: neighbor table overflow!
[11474143.318807] neighbour: arp_cache: neighbor table overflow!
[11474143.326468] neighbour: arp_cache: neighbor table overflow!
[11474143.329394] neighbour: arp_cache: neighbor table overflow!
[11474143.334250] neighbour: arp_cache: neighbor table overflow!
[11474143.335421] neighbour: arp_cache: neighbor table overflow!
[11474143.337814] neighbour: arp_cache: neighbor table overflow!
[11474143.340676] neighbour: arp_cache: neighbor table overflow!
We noticed when looking at our DHCP server hosted on the container & saw some failure messages on the server which resulted in re-transmits and a smalls spike in traffic.
I am having difficulty finding how to adjust the arp cache for the lxd (ubuntu 18.04.5)
It looks like I should be able to edit the sysctl.conf file and reload the container, using the following variables:
$ sysctl net.ipv4.neigh.default.gc_thresh1
net.ipv4.neigh.default.gc_thresh1 = 128
$ sysctl net.ipv4.neigh.default.gc_thresh2
net.ipv4.neigh.default.gc_thresh2 = 512
$ sysctl net.ipv4.neigh.default.gc_thresh3
net.ipv4.neigh.default.gc_thresh3 = 1024
But when I try to check them, I do not see that they are set.
I get this message when I try to check them:
sysctl: cannot stat /proc/sys/net/ipv4/neigh/default/gc_thresh3: No such file or directory
I don’t see them set in the /etc/sysctl.conf file either. It is just commented out all together.
sysctl -a reports a lot of flags/variables set, but none equate to the neighbor thresholds, that I can tell.
Is this something I have to set in the LXD config?
