We set up the container to have access to both /tmp/X11-unix/X0 and ~/.Xauthority of the host. And that’s it.
I did not see any need for other files file /dev/video0, etc. Works for me, Intel GPU.
It really mystified me that I would get the graphics performance without adding the gpu device.
I tried glxgears (still, without the gpu device, Intel GPU):
ubuntu@wine-games:~$ ls -l /dev/dri
ls: cannot access '/dev/dri': No such file or directory
ubuntu@wine-games:~$ glxgears
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
356 frames in 5.0 seconds = 71.028 FPS
300 frames in 5.0 seconds = 59.981 FPS
A reader in the blog post reported that it did not work for them, and I suggested they try adding the gpu device.
