I am a relative newbie to linux administration, so please excuse my ignorance. I’m trying to setup a second LXC storage pool.
After running
lxc storage create storage_pool_2 btrfs source=/dev/sda size=64GB
I get the error message
Error: Failed to create the BTRFS pool: /dev/sda appears to contain a partition table (dos).
ERROR: use the -f option to force overwrite of /dev/sda
btrfs-progs v4.15.1
See http://btrfs.wiki.kernel.org for more information.
Here is what lsblk is showing:
NAME FSTYPE SIZE MOUNTPOINT LABEL
loop0 btrfs 81G /var/lib/lxd/storage-pools/default default
sda 446.6G
└─sda1 LVM2_member 446.6G
├─marmoset--eugo--2--vg-root ext4 445.7G /
└─marmoset--eugo--2--vg-swap_1 swap 980M [SWAP]
My lxc storage list is just from the default lxc setup:
| default | | btrfs | /var/lib/lxd/disks/default.img | 26 |
Could someone please tell me what am I doing wrong here? (I haven’t tried the -f option yet, as I’m hesitant to force anything to do with the drive when I don’t understand what it does. Just in case it leads to loss of data.)
