$ lxc list
| cont1 | RUNNING | | | PERSISTENT | 0 |
In order to attach a device to a container, I run the below command:
lxc config device add cont1 data disk source=/dev/sdb path=/mnt limits.read=4MB
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 10G 0 disk
├─sda1 8:1 0 9.9G 0 part /
├─sda14 8:14 0 4M 0 part
└─sda15 8:15 0 106M 0 part /boot/efi
sdb 8:16 0 100G 0 disk
If I remove the parameter limits.read, it works. As I could read in this website (incus/doc/storage.md at main · lxc/incus · GitHub), I/O limits can be set on storage devices when attached to a container.
Could you let me know why I’m getting that error?
There is not info related to this problem inside of logs.
Hmm, any chance you can upgrade to LXD 2.21 (apt install -t artful-backports lxd lxd-client), that should get you a number of bugfixes and if not one for this particular case, it’ll at least make it easier for us to debug what’s going on.
I am trying to add a block device to the container (to use docker 1.12 on centos7 for openshift)
$ lsblk /dev/sdm
sdm 8:192 1 119,3G 0 disk
└─sdm1 8:193 1 119,3G 0 part
$ lxc list => | centos7 | RUNNING | 10.46.99.40 (eth0) | | PERSISTENT | 0
which creates
$ ll /var/snap/lxd/common/lxd/devices/centos7/unix.myblockdevice.dev-sdm
brw-rw---- 1 root root 8, 192 Feb 27 00:23 /var/snap/lxd/common/lxd/devices/centos7/unix.myblockdevice.dev-sdm
(this looks like the right block device)
The selinux/apparmor config seems to be the issue… OMG
Although I can see all devices in a privileged container using lsblk ?!?, they will only show up in /dev when I configure them using e.g. lxc config device add centos7 mydockerdisk unix-block source=/dev/sdm lxc config device add centos7 mydockerpartition unix-block source=/dev/sdm1
centos7$ mount | grep /dev/sdm /dev/nvme0n1p1 on /dev/sdm type ext4 (rw,relatime,errors=remount-ro,data=ordered)
this is a bit confusing… but seems to work.
I can mount the disk device and create partitions.
However, this doesnt create the device nodes in the container (I suppose this is a security feature)
Those only show when I configure the devices in the config of the container!
now things start to look better.
Just dont look at the mount table as its confusing!
So this works for simple block devices…
But now the minishift installation requires device mapper…
This fails with kernel modules vs libdevmapper mismatch…
I am now getting tempted to go back to kvm.
LXD seems not be able yet to deal with the complex issues coming from running nested but different linux systems and nested virtualization …
I did get the latest docker17.12 to work though
inside centos 7.4
inside LXD on ubuntu 16.04
using btrfs…
