(I’m testing out MAAS 3.0’s ability to use LXD as a VM orch instead of virsh, it’s great!)
I have a LXD VM, created and deployed via MAAS. After deploy I ssh to the host and pass through a block device from the host like this:
lxc config device add vm1 sdb disk source=/dev/sdb
After starting up the VM and ssh’ing into it, I see the block device is there, but it’s sda. I reboot the VM and next time around it’s sdc. etc…
Should I be using disk-by-id as the source=from the host?
Should I be using target=/dev/sdb on the VM?
Should I have added the second disk to the VM before first boot?
(I will try these things next)
