I installed a new SSD on my Ubuntu 20.04 system and want to reinstall LXD on my host and have it create.
So I did the following:
$ sudo snap install lxd
lxd 4.20 from Canonical✓ installed$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (lvm, zfs, ceph, btrfs, dir) [default=zfs]: btrfs
Create a new BTRFS pool? (yes/no) [default=yes]:
Would you like to use an existing empty block device (e.g. a disk or partition)? (yes/no) [default=no]: yes
Path to the existing block device: /dev/sdd
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
Would you like the LXD server to be available over the network? (yes/no) [default=no]: yes
Address to bind LXD to (not including port) [default=all]:
Port to bind LXD to [default=8443]:
Trust password for new clients:
Again:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]
Would you like a YAML “lxd init” preseed to be printed? (yes/no) [default=no]:
After a few seconds it returns with this error:
Error: Failed to create storage pool ‘default’: Failed to format block device: Failed to run: mkfs.btrfs -L default /dev/sdd: /dev/sdd appears to contain a partition table (gpt).
ERROR: use the -f option to force overwrite of /dev/sdd
NOTE:
Before I ran the above I had used FDISK to delete any partition table on that disk (/dev/sdd)
rebooted.
So I am not sure why LXD INIT thinks there is a GPT partition table on it?
brian
