Authentication protocol is not compatible with authorization driver
Hi, since enabling SSO on the Incus Web UI, I’m seeing quite a few of these messages in the incusd.log log file. Can anyone tell me what it means and (I know it’s only a warning) whether I should be worried, or at least whether there are any implications I should be aware of?
time="2025-05-31T16:25:58+01:00" level=warning msg="Authentication protocol is not compatible with authorization driver" driver=tls protocol=oidc
Are you using one of the authorizers (openfga or authorization scriptlet)?
Hi, I’m afraid I went into it as a “user” without really understanding ‘all’ the options. I followed the instructions here using an account with “Auth0”. (so I don’t think I’m using openfga, and I’m not sure what an authorization scriptlet is?)
Essentially I signed up for a free Auth0 account, then pasted the details in to the Incus UI.
Okay, so you’re in a situation where you have external authentication (OIDC) but no authorizer that can handle it. The warnings can be safely ignored, it’s basically just a reminder (a bit of a noisy one) that everyone with a valid account in your OIDC provider is getting full admin privileges on Incus.
Ok, so in my case the Incus UI isn’t publicly visible (VPN only), but if it was, presumably the “disable signups” I also have set would prevent anyone else from obtaining an account … I’ve just spotted the authorizer docs, will go have a read, sounds like I should probably add this too … :slight_smile:
