I’m trying to create a ramdisk within an LXD container. Unfortunately, I don’t think that this uses /etc/fstab
in the container, so I need to figure out how to create a ramdisk object that can be used inside an LXD container.
Is there any straightforward way to define this in the LXD container’s configuration to define a ramdisk that is mounted within the container?
