what is the best way to manage vlan on incusOS.
On my server, I only have 1 nic.
I add a physical interface with role instance on my configuration
incus admin os system edit network
interfaces:
- addresses:
- dhcp4
- slaac
hwaddr: bc:24:11:04:dc:4e
required_for_online: "no"
roles:
- instances
vlan_tags:
- 20
- 10
- 40
- 50
time:
timezone: UTC
state:
interfaces:
ens18:
addresses:
- 192.168.99.230
mtu: 1500
roles:
- instances
- management
- cluster
and then add the specific vlan to my instance with a terraform like this:
resource "incus_profile" "iot_vlan20" {
name = "iot_vlan20"
device {
name = "eth0"
type = "nic"
properties = {
nictype = "physical"
parent = "ens18"
vlan = "20"
Is this the right way to do it ? Do you recommend another way ?
Regards,
Edouard
