hello,
debian unstable host with
lxd 5.0.1-3 coming from official debian repository
unpriviliged container running debian unstable (also fails with other images i tested, so i guess the image doesnt really matter)
i need to create a proxy for an unix domain socket in /run/user/1000/foo in a container. i use the following profile
config: {}
description: foo passthrough profile
foo:
bind: container
connect: unix:/run/user/1000/foo
gid: "1000"
listen: unix:/run/user/1000/foo
mode: "0700"
security.gid: "1000"
security.uid: "1000"
type: proxy
uid: "1000"
when i apply the profile to a container it does not start up any more:
Error: Error occurred when starting proxy device: Error: Failed to listen on /run/user/1000/foo: listen unix /run/user/1000/foo: bind: no such file or directory
Try `lxc info --show-log bar` for more info
i guess this happens because /run/user/1000 does not exist at the time lxd tries to create the bind.
my workaround right now is to create the bind in /home/user/$(id -nu 1000)/foo and symlink to this with a systemd unit which is executed after boot in the container.
this does not really feel clean to me so i thought i’d ask if there are other possibilities which can be achieved by only using lxd configuration options.
