Hey there! After upgrade upto debian 12 and lxc 5, lxc-info always shows BlkIO use: 0 bytes
# lxc-info -n test-2.fr
State: RUNNING
PID: 847679
IP: 192.168.51.208
CPU use: 0.88 seconds
BlkIO use: 0 bytes
Memory use: 49.13 MiB
KMem use: 5.06 MiB
Link: vethiMj8Eq
TX bytes: 1.65 KiB
RX bytes: 706.34 KiB
Total bytes: 707.99 KiB
Very strange thing, that the docker also shows 0 in BLOCK I/O docker stats. Maybe i should use some kernel/cgroups params or something?
# lxc-checkconfig
LXC version 5.0.2
Kernel configuration not found at /proc/config.gz; searching...
Kernel configuration found at /boot/config-6.1.0-10-amd64
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup namespace: enabled
Cgroup v1 mount points:
- /sys/fs/cgroup/systemd
- /sys/fs/cgroup/cpu,cpuacct
- /sys/fs/cgroup/misc
- /sys/fs/cgroup/net_cls,net_prio
- /sys/fs/cgroup/devices
- /sys/fs/cgroup/cpuset
- /sys/fs/cgroup/memory
- /sys/fs/cgroup/freezer
- /sys/fs/cgroup/rdma
- /sys/fs/cgroup/hugetlb
- /sys/fs/cgroup/pids
- /sys/fs/cgroup/blkio
- /sys/fs/cgroup/perf_event
Cgroup v2 mount points:
- /sys/fs/cgroup/unified
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Macvlan: enabled, not loaded
Vlan: enabled, loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities: enabled
