hello,
here all configs and commands i used
# lxc network show lxdbr0-acl
ipv4.address: 10.228.15.1/24
ipv4.nat: "true"
ipv6.address: fd42:8572:a718:e314::1/64
ipv6.nat: "true"
security.acls: test-acl
security.acls.default.egress.action: allow
security.acls.default.ingress.action: allow
type: bridge
- /1.0/instances/ct-acl
- /1.0/profiles/profile-acl
managed: true
status: Created
locations:
- none
# lxc config show ct-acl
image.architecture: amd64
image.description: ubuntu 22.04 LTS amd64 (release) (20220902)
image.label: release
image.os: ubuntu
image.release: jammy
image.serial: "20220902"
image.type: squashfs
image.version: "22.04"
volatile.base_image: 95f82d22bea6a0d20dc3c06a59929b768abd0c7243d5298c3973f1808688d117
volatile.cloud-init.instance-id: a438dcb8-06db-4c62-866a-8a77d135b239
volatile.eth0.host_name: veth58fb7177
volatile.eth0.hwaddr: 00:16:3e:93:4c:bf
volatile.eth0.name: eth0
volatile.idmap.base: "0"
volatile.uuid: 4336cc6b-0134-4b69-938a-8d9e690d009a
devices: {}
- profile-acl
my commands:
# network and acls
lxc network create lxdbr0-acl
lxc network acl create test-acl
lxc network acl rule add test-acl egress destination=172.17.0.22/32 action=allow
lxc network acl rule add test-acl egress destination=172.17.0.0/24 action=reject
lxc network set lxdbr0-acl security.acls.default.egress.action=allow security.acls.default.ingress.action=allow security.acls=test-acl
# ct
lxc launch ubuntu:22.04 ct-acl
# profile
lxc profile copy default profile-acl
lxc profile device remove profile-acl eth0
lxc profile device add profile-acl eth0 name=eth0 network=lxdbr0-acl type=nic
lxc profile add ct-acl profile-acl
lxc profile remove ct-acl default
i cannot ping the ip 172.17.0.22 from inside container:
# lxc exec ct-acl -- ping 172.17.0.22 -c 1
PING 172.17.0.22 (172.17.0.22) 56(84) bytes of data.
From 10.228.15.1 icmp_seq=1 Destination Port Unreachable
--- 172.17.0.22 ping statistics ---
1 packets transmitted, 0 received, +1 errors, 100% packet loss, time 0ms
removing the deny rule then it works
lxc network acl rule remove test-acl egress destination=172.17.0.0/24 action=reject
64 bytes from 172.17.0.22: icmp_seq=1 ttl=61 time=11.8 ms
rtt min/avg/max/mdev = 11.809/11.809/11.809/0.000 ms
