Hello, I was trying to setup a quick 2 nodes cluster using 2 bare-metal install of ubuntu 20.04 when I faced this issue.
I configured a bridge br0 on each node to be used by the containers, so far everything is working:
network:
  ethernets:
    enp0s31f6:
      dhcp4: false
      dhcp6: false
  bridges:
    br0:
      dhcp4: true
      interfaces: [enp0s31f6]
  version: 2
cluster is up and running, I can create containers with internal IPs everything works fine.
But I created the following profile to get containers to have 1 internal IP and 1 IP on my LAN :
  user.network-config: |
    version: 1
      - type: physical
        subnets:
          - type: dhcp
            ipv4: true
      - type: physical
        subnets:
          - type: dhcp
            ipv4: true
description: LXD profile with private and public networks
    network: lxdfan0
  eth1:
    nictype: bridged
    parent: br0
    pool: local
- /1.0/instances/ubuntu01
the problem is whenever I try to boot up the container, it gets an IP fine, but the host on which it lives becomes completely unreachable. can’t ping, can’t ssh, other cluster node can’t see it.
I’m kind of out of ideas…
