Need some help with my lxd bridge.
I want it be able to communicate with my entire network. But seems that some type of forwarding wont work and i cant figure it it out. Ive googled and read other threads here. But no answer.
System:
Ubuntu 22.04.1 LTS.
LXD/lxc snap
Stock UFW so nftables i assume.
Standard lxd bridge with subnet 9.9.9.1/24
LAN 192.168.1.1 net.
Router: pfsense software
Settings ive done.
Ive done ip forwarding in /etc/ufw/sysctl.conf in the container and host. rebooted server with no change.
Added UFW firewall rules.
sudo ufw allow in on lxdbr0
sudo ufw route allow in on lxdbr0
sudo ufw route allow out on lxdbr0
Ufw on the bridged container is disabled. Also tried with ufw disabled on host. No change.
Pingstests.
Ping to router: 100% works
Ping from router: 100% packet loss
Ping from host: Yes 100% works
Ping from wifi thats connected as accesspoint: 100% loss (duh but i wanted to try everything)
Ping from other lxc on macvlan (192.168.1.1): 100% loss
Ping from the (9.9.9.1 subnet) lxc to macvlan lxc: 100% works
So the bridge/lxc is blocking incoming connections. Whats missing?
