When I create a new container, as soon as I initiate any network activity (eg an apt update), two new default routes appear on the host, disrupting networking. At present I am dealing with this by manually deleting them (which doesn’t seem to cause any problems for the container or Incus), but I would like to know how I can prevent this.
Steps to reproduce:
create new container
incus launch images:debian/12 test -
make an outbound connection inside the container
$ incus shell test
root@test:~# apt update
- compare ip route output on host
$ ip route
default via 192.168.1.1 dev enp1s0
10.51.132.0/24 dev incusbr0 proto kernel scope link src 10.51.132.1
169.254.0.0/16 dev vetha3ea216e proto kernel scope link src 169.254.161.152
169.254.0.0/16 dev veth367c4bc7 proto kernel scope link src 169.254.168.53
192.168.1.0/24 dev enp1s0 proto kernel scope link src 192.168.1.229
192.168.1.1 dev enp1s0 scope li0.0.0.0 dev veth6284239d scope link
AFTER
default dev veth6284239d scope link
169.254.0.0/16 dev veth6284239d proto kernel scope link src 169.254.173.106
192.168.1.1 dev enp1s0 scope link
This is a minimal Incus install that followed the defaults with an Incus-managed bridge network:
$ incus profile show default
config: {}
incusbr0:
nictype: bridged
parent: incusbr0
pool: default
The new default routes disrupt networking because some applications try to use the container’s virtual interface instead of the enp1s0 interface.
