I have setup an Ubuntu server LTS inside Parallels Desktop Preview for M1 using a BTRFS partition mounted at /btrfs and this is set as the default storage pool.
I am running unit test on creating a container, which works fine on the ZFS server. No matter how many times I run it, I get the same error, just a different file.
"type": "sync",
"status": "Success",
"status_code": 200,
"operation": "",
"error_code": 0,
"error": "",
"metadata": {
"id": "a6538030-6f28-4e19-8269-81984d4b91a7",
"class": "task",
"description": "Starting instance",
"created_at": "2021-02-12T16:37:25.422106169Z",
"updated_at": "2021-02-12T16:37:25.424997113Z",
"status": "Failure",
"status_code": 400,
"resources": {
"instances": [
"/1.0/instances/itest"
"metadata": {
"container_progress": "Remapping container filesystem"
"may_cancel": false,
"err": "Failed preparing container for start: Failed to change ownership of: /var/snap/lxd/common/lxd/storage-pools/default/containers/itest/rootfs/usr/lib/apt/apt.systemd.daily",
"location": "none"
This issue appears constantly during the unit tests, but not in normal usage, so I am guessing it the equivalent of ZFS busy errors as I am hammering it.
Any thoughts?
note. This morning when I booted up I was getting Error occurred when starting proxy device: Error: Failed to receive fd from listener process errors, in the end I had to restart to make that go away.
